查看: 1621|回复: 6
检验报告常用缺陷简单英文描述汇总--材料(2)
发表于 2010-1-5 17:38:51 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Burr 毛边,飞边
Shinking 缩收
Sharp edge 尖锐边
color deviation 色差
cut by worker without
approval
未经同意切削
material mark 材料痕
shining abnormal 异常发亮
fail frozen testing/missle test 冷冻/导弹测试失败
injection defect, not functional problem--注不满
injection defect, functional problem--注不满, 影响功能
white mark 白痕, 发白
joint finger
指接
wood texture incorrect 木头纹理不正确
Moisture outside the scope (8~14 degree) 湿度不满足要求
Worm hole 虫孔
Decayed parts 腐烂
Waney component
Water stains
warp (the max deformation is less than 1/8 inch) 翘曲,小于1/8“
warp (the max deformation is more than 1/8 inch) 翘曲,大于1/8“
Mineral streak line 矿物纹
Fast/dead knot
死结
Live knot 活结
Chip---doesn't cause sharp point 碎片不引起尖锐点
Chip---does cause sharp point 碎片引起尖锐点
Crack ---affect safety concern 裂缝影响功能
Crack---lobed crack (表裂)
Split
开裂
Dent ---doesn't expose on visible position or depth
less than 1 mm
弯曲,不可视或小于1mm
Dent --- expose on visible position or depth more
than 1 mm
弯曲,可视或大于1mm
Indentation
凹痕
Gluing position with gap 胶粘,有缝隙
Gluing line is obvisible 胶粘线可视
incorrect texture
纹理不正确
string broken or emersion
断线或脱线
slight color deviation
轻微色差
serious color deviation 严重色差
softgoods fail test, 色牢度,抗撕,抗拉,耐磨性 测试失败
thickness doesn't meet request
密度不满足要求
pin left in softgoods
断针
发表于 2010-1-5 18:06:12 | 只看该作者
拿个沙发,非常不错...
发表于 2010-1-5 20:39:19 | 只看该作者
谢谢,这样多好,不用金币也可看
发表于 2010-1-6 09:14:58 | 只看该作者
很實用,感謝分享
发表于 2010-1-31 10:37:13 | 只看该作者
不错,谢谢了
发表于 2013-12-26 08:29:26 | 只看该作者
Thanks for share
发表于 2014-7-29 07:29:03 | 只看该作者
学习一下
GMT+8, 2026-10-18 15:07 , Processed in 0.059247 second(s), 18 queries , Gzip On.
