查看: 4685|回复: 19
美国家具标准(ANSI furniture standards)
发表于 2009-9-25 13:49:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
ANSI |  BS |  DIN |  EN |  GB |  ISO |  JIS |  NF |  DIC
________________________________________
编号        中文名称        英文名称
ANSI/ASTM D3453-2001         软质泡沫材料规范.家具、汽车软垫、床垫及类似用途用氨基甲酸乙酯         Specification for Flexible Cellular Materials - Urethane for Furniture and Automotive Cushioning, Bedding, and Similar Applications
ANSI/ASTM E1352-2002         模拟装璜家具组装件的抗香烟引燃性的试验方法         Test Methods For Cigarette Ignition Resistance Of Mock-Up Upholstered Furniture Assemblies
ANSI/ASTM E1353-2002         装璜家具部件抗香烟引燃性试验方法         Test Methods For Cigarette Ignition Resistance Of Components Of Upholstered Furniture
ANSI/ASTM E1537-2007         软垫家具燃烧测试的试验方法         Test Method for Fire Testing of Upholstered Furniture
ANSI/ASTM E2280-2003         对医疗保健设施的病房内用的软垫座椅家具受火灾影响进行评估的指南         Guide for the Fire Hazard Assessment of the Effect of Upholstered Seating Furniture Within Patient Rooms of Health Care Facilities
ANSI/ASTM F1178-2001         上釉系统、烘干、金属连接件装置和家具的性能规范         Specification for Performance of Enameling System, Baking, Metal Joiner Work and Furniture
ANSI/ASTM F1550-2001         利用台架规模测定暴力行为后教养院用合成床垫或家具构件火焰试验响应特性试验方法         Test Method for Determination of Fire-Test-Response Characteristics of Components or Composites of Mattresses or Furniture for Use in Correctional Facilities after Exposure to Vandalism, by Employing a Bench Scale
ANSI/ASTM F1870-2001         评定拘留所和管教所装饰家具着火试验方法选择指南         Guide for Selection of Fire Test Methods for Assessment of Upholstered Furnishings in Detention and Correctional Facilities
ANSI/ASTM F420-1999         真空吸尘器可伸入家具底部深度的测试方法         Test Method for Access Depth under Furniture of Vacuum Cleaners
ANSI/ASTM F782-2001         船用家具门规范         Specification for Doors, Furniture, Marine
ANSI/ASTM F825-1993         抽屉、家具船用钢规范         Specification for Drawers, Furniture, Marine, Steel
ANSI/ASTM F826-1994         顶盖、家具船用钢规范         Specification for Tops, Furniture, Marine, Steel
ANSI/BIFMA M7.1-2007         测定从办公家具、部件和座椅中排放出的挥发性化合物(VOC)的标准试验方法         Standard Test Method for Determining VOC Emissions From Office Furniture, Components and Seating
ANSI/BIFMA X5.1-2002         办公家具.通用办公椅.试验         Office Furnishings - General-Purpose Office Chairs - Tests
ANSI/BIFMA X5.4-2005         办公家具.休息室座椅测试标准         Standard for Office Furnishing - Lounge Seating - Tests
ANSI/BIFMA X5.6-2003         办公家具.大板系统.试验         Office Furnishings - Panel Systems - Tests
ANSI/BIFMA X5.9-2004         办公室贮藏用家具标准.试验         Standard for Office Furniture Storage Units - Tests
ANSI/BIFMA X7.1-2007         低排放办公家具装置和座椅的甲醛和TVOC排放物用标准         Standard for Formaldehyde and TVOC Emissions of Low-emitting Office Furniture Systems and Seating
ANSI/BIFMA/SOHO S6.5-2001         小型办公室/家庭办公室家具.试验         Small Office/Home Office Furniture -Tests
ANSI/NFPA 260-2003         已装璜家具的部件对香烟烟火的阻燃性         Cigarette Ignition Resistance of Components of Upholstered Furniture
ANSI/NFPA 261-2003         已装璜家具材料组件对香烟烟火的阻燃性         Resistance of Mock-Up Upholstered Furniture Material Assemblies to Ignition by Smoldering Cigarettes
ANSI/NFPA 264A-1994         用耗氧式量热计测量已装璜家具零部件或其组合体和坐垫放热率的试验方法         Method of Test for Heat Release Rates for Upholstered Furniture Components or Composites and Mattresses Using an Oxygen Consumption Calorimeter
ANSI/NSF 49(i11)-2006         II级(层流)生物安全细木家具         Class II (laminar flow) biosafety cabinetry
ANSI/NSF 49-2002         二级(层流)生物危害的细木家具         Class II (Laminar Flow) Biohazard Cabinetry
ASTM D 1912-2000         家具革耐冻裂性的标准试验方法         Standard Test Method for Cold-Crack Resistance of Upholstery Leather
ASTM D 2097-2003         家具皮革表层挠曲测试的标准试验方法         Standard Test Method for Flex Testing of Finish on Upholstery Leather
ASTM D 3136-2004         服装、纺织品、家具织物和皮革制品用保养说明标签的标准术语         Standard Terminology Relating to Care Labeling for Apparel, Textile, Home Furnishing, and Leather Products
ASTM D 3453-2007         家具和汽车软垫、床垫及类似用途用软质泡沫材料-氨基甲酸乙酯的标准规范         Standard Specification for Flexible Cellular Materials-Urethane for Furniture and Automotive Cushioning, Bedding, and Similar Applications
ASTM D 3751-1994         家具抛光剂评定的标准实施规范         Standard Practice for Evaluation of Furniture Polish
ASTM D 4113-2002         机织家具套织物的标准性能规范         Standard Performance Specification for Woven Slipcover Fabrics
ASTM D 4771-2002         室内家具编织装饰用纤维的标准性能规范         Standard Performance Specification for Knitted Upholstery Fabrics for Indoor Furniture
ASTM D 5253-2004         地板覆盖物和纺织材料装饰家具的相关标准术语         Standard Terminology Relating to Floor Coverings and Textile Upholstered Furniture
ASTM D 7023-2006         与家用家具相关的标准术语         Standard Terminology Relating to Home Furnishings
ASTM E 1353-2002         装饰性家具部件的耐香烟点燃性的标准试验方法         Standard Test Methods for Cigarette Ignition Resistance of Components of Upholstered Furniture
ASTM E 1474-2007         用小型耗氧热量计测定装饰家具和床垫部件或组件的放热率的标准试验方法         Standard Test Method for Determining the Heat Release Rate of Upholstered Furniture and Mattress Components or Composites Using a Bench Scale Oxygen Consumption Calorimeter
ASTM E 1537-2007         软垫家具着火测试的标准试验方法         Standard Test Method for Fire Testing of Upholstered Furniture
ASTM E 2280-2003         医疗保健设施的病房内装璜有软垫的座式家具作用的着火危险评定的标准导则         Standard Guide for Fire Hazard Assessment of the Effect of Upholstered Seating Furniture Within Patient Rooms of Health Care Facilities
ASTM F 1178-2001         金属连接件和家具烘烤涂漆系统的性能用标准规范         Standard Specification for Performance of Enameling System, Baking, Metal Joiner Work and Furniture
ASTM F 1550-2005         用实验室耗氧热量计测定遭破坏后修复设施中床垫或家具用部件或合成材料燃烧试验响应特性的标准试验方法         Test Method for Determination of Fire-Test-Response Characteristics of Components or Composites of Mattresses or Furniture for Use in Correctional Facilities after Exposure to Vandalism, by Employing a Bench Scale Oxygen Consumption Calorimeter
ASTM F 1870-2005         拘留和惩罚设施中装饰家具评定用着火试验方法选择的标准指南         Standard Guide for Selection of Fire Test Methods for the Assessment of Upholstered Furnishings in Detention and Correctional Facilities
ASTM F 420-2004         真空吸尘器可伸入家具底部深度的标准测试方法         Standard Test Method for Access Depth Under Furniture of Vacuum Cleaners
ASTM F 782-2001         船用家具门的标准规范         Standard Specification for Doors, Furniture, Marine
ASTM F 826-1994         钢制船用家具顶盖         Standard Specification for Tops, Furniture, Marine, Steel
UL 1286-1999         办公家具         (Office furnishings )
UL 962-2003         家用和商用家具         (Household and commercial furnishings )
发表于 2009-10-15 09:31:40 | 只看该作者
ANSI/BIFMA/SOHO S6.5-2001,
斑竹,有没有上面的标准可以分享阿?
发表于 2009-10-22 12:41:07 | 只看该作者
谢谢 楼主的分享
发表于 2010-7-29 10:18:11 | 只看该作者
谁有这个标准啊,能发给我一份分享一下,邮箱253912855·.com 谢谢!
发表于 2010-7-30 14:59:48 | 只看该作者
奖章
奖章真多,五星上将啊!
发表于 2010-8-1 10:56:30 | 只看该作者
光说没内容咋整啊
发表于 2010-12-3 11:27:22 | 只看该作者
真全面~~~~~~~~~
发表于 2011-4-19 15:50:55 | 只看该作者
没有内容也没什么用啊
发表于 2011-6-21 16:46:13 | 只看该作者
很不错,如果有内容就更好啦!!!
发表于 2011-6-29 17:36:08 | 只看该作者
美国户外家具用什么标准? LZ 有答案吗?
GMT+8, 2026-9-20 13:34 , Processed in 0.036337 second(s), 20 queries , Gzip On.
