查看: 1874|回复: 2
英国家具标准(BS furniture standards)
发表于 2009-9-25 13:46:32 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
ANSI |  BS |  DIN |  EN |  GB |  ISO |  JIS |  NF |  DIC
________________________________________
编号        中文名称        英文名称
BS 3044-1990         办公室家具设计和选择的人类工效学原理指南         Guide to Ergonomics principles in the design and selection of office furniture
BS 3129-1959         家具用胶乳泡沫橡胶部件规范         Specification for latex foam rubber components for furniture
BS 3962-1-1980         木制家具漆面的试验方法.用85°角的镜面光泽测量做低角度眩光的评定         Methods of test for finishes for wooden furniture - Assessment of low angle glare by measurement of specular gloss at 85 °
BS 3962-5-1980         木制家具精整试验方法.第5部分:表面耐冷凝油和脂肪性评定         Methods of test for finishes for wooden furniture - Assessment of surface resistance to cold oils and fats
BS 3962-6-1980         木制家具精整试验方法.第6部分:耐机械损伤性评定         Methods of test for finishes for wooden furniture - Assessment of resistance to mechanical damage
BS 4723-2002         装饰家具用弹性罩布规范         Stretch covers for upholstered furniture - Specification
BS 4875-1-2007         家具的强度和稳定性.家用座椅结构的强度和耐久性要求         Strength and stability of furniture - Requirements for the strength and durability of the structure of domestic seating
BS 4875-5-2001         家具的强度和稳定性.家用和定做用桌子及小台车的强度、耐用性和稳定性要求         Strength and stability of furniture - Requirements for strength, durability and stability of tables and trolleys for domestic and contract use
BS 4875-7-2006         家具的强度和稳定性.家用和订做储藏家具.性能要求         Strength and stability of furniture - Domestic and contract storage furniture - Performance requirements
BS 4875-8-1998         家具.家具的强度和稳定性.测定非家用储存家具稳定性的方法         Furniture - Strength and stability of furniture - Methods for determination of stability of non-domestic storage furniture
BS 5218-1989         木材防腐剂.用幼虫转化(实验室法)测定抗家具窃蠹(De Geer)毒值         Wood preservatives - Determination of the toxic values against Anobium punctatum (De Geer) by larval transfer (laboratory method)
BS 5459-2-2000         办公室家具的性能要求与试验规范.体重在150kg和其以下人员坐的,每天使用时间达24个小时的办公室脚踏椅型号         Specification for performance requirements and tests for office furniture - Office pedestal seating for use by persons weighing up to 150 kg and for use up to 24 hours a day, including type-approval tests for individual components
BS 5852-1-1979         家具的防火试验.第1部分:座椅软垫合成物燃烧材料可燃性的试验方法         Fire tests for furniture Part 1. Methods of test for the ignitability by smokers' materials of upholstered composites for seating
BS 5852-2-1982         英国标准的家具用防火试验.第2部分:用燃烧源测定座椅用软垫合成物可燃性的试验方法         British Standard Fire tests for furniture Part 2. Methods of test for the ignitability of upholstered composites for seating by flaming sources
BS 6261-1982         装饰性家具构件之间的配合及应用评估方法         Method for evaluating the application of and interaction between components in upholstered furniture
BS 6396-2002         办公室家具和办公室屏幕的电器系统.规范         Electrical systems in office furniture and office screens - Specification
BS 6608-1985         装饰家具用牛皮革规范         Specification for cattle hide leathers for upholstered furniture
BS 7176-2007         采用测试复合料的非家用座椅用装饰家具的耐燃性规范         Specification for resistance to ignition of upholstered furniture for non-domestic seating by testing composites
BS 8474-2006         家具.带电力驱动支持表面的椅子.要求         Furniture - Chairs with electrically operated support surfaces - Requirements
BS CWA 14248-2001         FunStep(家具产品和商业数据).funStep的应用活动模型.AAM         FunStep (furniture product and business data) - funStep application activity model - AAM
BS CWA 14249-2002         FunStep(家具产品和商业数据).FunStep应用参考模型.ARM         FunStep (furniture product and business data) - funStep application reference model - ARM
BS CWA 14515-2002         在国际互联网上建立门式和拍卖房屋的家具和产品类型的不同类型模式         Model of different categories of furniture and types of products created to build a portal and an auction house over the internet
BS DD CEN/TS 15185-2006         家具.表面耐摩擦性评定         Furniture - Assessment of the surface resistance to abrasion
BS DD CEN/TS 15186-2006         家具.表面耐擦伤性的评定         Furniture - Assessment of the surface resistance to scratching
BS DD ENV 12520-2000         家具.座椅.机械和结构安全性要求         Domestic furniture - Seating - Mechanical and structural safety requirements
BS DD ENV 12521-2000         家具.桌子.机械和结构安全性要求         Domestic furniture - Tables - Mechanical and structural safety requirements
BS DD ENV 13759-2001         家具.座椅.活动沙发床斜靠和/或微倾机构以及操作机构的耐用性能测定的试验方法         Domestic furniture - Seating - Test method for the determination of the durability of reclining and/or tilting mechanisms and operating mechanisms for convertible sofa beds
BS DD ENV 14443-2004         家用家具.座椅.家具覆盖饰物耐用性测定的试验方法         Domestic furniture - Seating - Test methods for the determination of durability of upholstery
BS DD ENV 581-2-2000         室外家具.野营、家用和工作用桌椅.桌椅的机械安全性要求和试验方法         Outdoor furniture - Seating and tables for camping, domestic and contract use - Mechanical safety requirements and test methods for seating
BS EN 1021-1-2006         家具.装饰家具着火性的评估.燃着的香烟火源         Furniture - Assessment of the ignitability of upholstered furniture - Part 1: Ignition source smouldering cigarette
BS EN 1021-2-2006         家具.装饰家具着火性的评估.与火柴火焰等同的火源         Furniture - Assessment of the ignitability of upholstered furniture - Part 2: Ignition source match flame equivalent
BS EN 1022-2005         居室家具.座椅.稳定性测定         Domestic furniture - Seating - Determination of stability
BS EN 1023-1-1997         办公家具.遮板.尺寸         Office furniture - Screens - Dimensions
BS EN 1023-2-2000         办公家具.遮板.机械安全性要求         Office furniture - Screens - Mechanical safety requirements
BS EN 1023-3-2000         办公家具.遮板.试验方法         Office furniture - Screens - Test methods
BS EN 1116-2004         厨房家具.厨房家具和器具的协调尺寸         Kitchen furniture - Co-ordinating sizes for kitchen furniture and kitchen appliances
BS EN 1129-1-1995         家具.折叠床.安全技术要求和检验方法.安全性要求         Furniture - Foldaway beds - Safety requirements and testing - Safety requirements
BS EN 1129-2-1995         家具.折叠床.安全技术要求和检验方法.试验方法         Furniture - Foldaway beds - Safety requirements and testing - Test methods
BS EN 1130-1-1997         家具.家用框形物和摇篮.安全性要求         Furniture - Cribs and cradles for domestic use - Safety requirements
BS EN 1130-2-1996         家具.家用框形物和摇篮.试验方法         Furniture - Cribs and cradles for domestic use - Test methods
BS EN 12522-1-1998         家具搬运业.私人家具搬运.服务规范         Furniture removal activities - Furniture removal for private individuals - Service specification
BS EN 12522-2-1998         家具搬运业.私人家具搬运.服务条款         Furniture removal activities - Furniture removal for private individuals - Provision of service
BS EN 12528-1999         脚轮和轮子.家具用脚轮.要求         Castors and wheels - Castors for furniture - Requirements
BS EN 12529-1999         脚轮和轮子.家具用脚轮.转椅用脚轮.要求         Castors and wheels - Castors for furniture - Castors for swivel chairs - Requirements
BS EN 12720-1997         家具.表面抗冷液性评估         Furniture - Assessment of surface resistance to cold liquids
BS EN 12721-1997         家具.表面湿热抗性评估         Furniture - Assessment of surface resistance to wet heat
BS EN 12722-1997         家具.表面抗干热性评估         Furniture - Assessment of surface resistance to dry heat
BS EN 12727-2000         家具.成排座椅.强度和耐久性试验方法和要求         Furniture - Ranked seating - Test methods and requirements for strength and durability
BS EN 13336-2004         皮革.装饰用皮革的特性.家具用皮革的选择指南         Leather - Upholstery leather characteristics - Guide for selection of leather for furniture
BS EN 1334-1996         家具.床和床垫.测量方法和推荐公差         Domestic furniture - Beds and mattresses - Methods of measurement and recommended tolerances
BS EN 1335-1-2000         办公家具.办公椅.尺寸.尺寸的测定         Office furniture - Office work chair - Dimensions - Determination of dimensions
BS EN 1335-2-2000         办公家具.办公椅.安全性要求         Office furniture - Office work chair - Safety requirements
BS EN 1335-3-2000         办公家具.办公椅.安全性试验方法         Office furniture - Office work chair - Safety test methods
BS EN 13453-1-2004         家具.非家用双层床和高床.安全、强度和耐用性要求         Furniture - Bunk beds and high beds for non-domestic use - Safety, strength and durability requirements
BS EN 13721-2004         家具.表面反射性的评定         Furniture - Assessment of the surface reflectance
BS EN 13722-2004         家具.表面光泽度的评定         Furniture - Assessment of the surface gloss
BS EN 13761-2002         办公家具.来访者用座椅         Office furniture - Visitors chairs
BS EN 14056-2003         实验室家具.设计和安装建议         Laboratory furniture - Recommendations for design and installation
BS EN 14072-2004         家具中的玻璃.试验方法         Glass in furniture - Test methods
BS EN 14073-2-2004         办公家具.储存用家具.安全要求         Office furniture - Storage furniture - Safety requirements
BS EN 14073-3-2004         办公家具.储存用家具.结构的稳定性和强度的测定用试验方法         Office furniture - Storage furniture - Test methods for the determination of stability and strength of the structure
BS EN 14074-2004         办公家具.桌子和储存用家具.可动部件的强度和耐用性的测定用试验方法         Office furniture - Tables and desks and storage furniture - Test methods for the determination of strength and durability of moving parts
BS EN 14465-2004         纺织品.家具装饰织物.规范和试验方法         Textiles - Upholstery fabrics - Specification and methods of test
BS EN 14703-2007         家具.非家用座椅连成一排的链接.强度要求和试验方法         Furniture - Links for non-domestic seating linked together in a row - Strength requirements and test methods
BS EN 14749-2006         家具和厨房贮藏设备和橱柜台面.安全要求和试验方法         Domestic and kitchen storage units and worktops - Safety requirements and test methods
BS EN 14873-1-2005         家具拆卸工作.家具的存储以及人为影响.第1部分:存储设施规范以及相关存储规定         Furniture removal activities — Storage of furniture and personal effects for private individuals — Part 1: Specification for the storage facility and related storage provision
BS EN 14873-2-2005         家具的存储以及对不同部分的人为影响.服务条款         Furniture removal activities — Storage of furniture and personal effects for private individuals — Part 2: Provision of the service
BS EN 15187-2006         家具.曝光量的影响评估         Furniture - Assessment of the effect of light exposure
BS EN 15373-2007         家具.强度、耐久性和安全.非家用座椅安全         Furniture - Strength, durability and safety - Requirements for non-domestic seating
BS EN 1725-1998         家具.床和床垫.安全要求和试验方法         Domestic furniture - Beds and mattresses - Safety requirements and test methods
BS EN 1728-2001         家具.座椅.强度和耐久性测定方法         Domestic furniture - Seating - Test methods for the determination of strength and durability
BS EN 1729-1-2006         家具.教育机构用桌椅.第1部分:功能尺寸         Furniture - Chairs and tables for educational institutions - Part 1: Functional dimensions
BS EN 1729-2-2006         家具.教育机构用桌椅.第2部分:安全要求和试验方法         Furniture - Chairs and tables for educational institutions -Part 2: Safety requirements and test methods
BS EN 1730-2000         家具.桌子.强度、耐久性和稳定性测定的试验方法         Domestic furniture - Tables - Test methods for determination of strength, durability and stability
BS EN 1957-2000         家具.床和床垫.功能特性测定方法         Domestic furniture - Beds and mattresses - Test methods for the determination of functional characteristics
BS EN 370-1993         木材防腐剂.防止家具产生窃蠹的根除效果的测定         Wood preservatives - Determination of eradicant efficacy in preventing emergence of Anobium punctatum (De Geer)
BS EN 424-2002         弹性地板覆盖物.模拟家具腿移动影响的测定         Resilient floor coverings - Determination of the effect of simulated movement of a furniture leg
BS EN 48-2005         木材防腐剂.家具窃蠹幼虫(窃蠹)根除剂作用的测定(实验室方法)         Wood preservatives - Determination of eradicant action against larvae of Anobium punctatum (De Geer) (laboratory method)
BS EN 49-1-2005         木材防腐剂.用产卵和幼虫成活法测定防家具窃蠹(De Geer)的保护效果.表面处理应用(实验室法)         Wood preservatives - Determination of the protective effectiveness against Anobium punctatum (De Geer) by egg-laying and larval survival - Application by surface treatment (laboratory method)
BS EN 49-2-2005         木材防腐剂.用产卵和幼虫成活法测定防家具窃蠹的(De Geer)保护效果.应用浸渍法(实验室法)         Wood preservatives - Determination of the protective effectiveness against Anobium punctatum (De Geer) by egg-laying and larval survival - Application by impregnation (laboratory method)
BS EN 527-1-2000         办公家具.工作桌和写字台.尺寸         Office furniture - Work tables and desks - Dimensions
BS EN 527-2-2003         办公家具.工作台和写字台.机械安全要求         Office furniture - Work tables and desks - Mechanical safety requirements
BS EN 527-3-2003         办公家具.工作台和写字台.结构的稳定性和机械强度测定的试验方法         Office furniture - Work tables and desks - Methods of test for the determination of the stability and the mechanical strength of the structure
BS EN 581-1-2006         户外家具.野营、家用和指定用座椅和桌子.一般安全要求         Outdoor furniture - Seating and tables for camping, domestic and contract use - General safety requirements
BS EN 581-3-2007         户外家具.野营、家用和办公用座椅和桌子.桌子的机械安全要求和试验方法         Outdoor furniture - Seating and tables for camping, domestic and contract use - Mechanical safety requirements and test methods for tables
BS EN 597-1-1995         家具.床垫和装饰床具的可燃性评定.火源:阴燃卷烟         Furniture - Assessment of the ignitability of mattresses and upholstered bed bases - Ignition source: smouldering cigarette
BS EN 597-2-1995         家具.床垫和装饰床具可燃性评定.火源:与火柴火焰同等的火源         Furniture - Assessment of the ignitability of mattresses and upholstered bed bases - Ignition source: match flame equivalent
BS EN 716-1-1996         家具.家用儿童帆布床和折叠床.安全性要求         Furniture - Children's cots and folding cots for domestic use - Safety requirements
BS EN 716-2-1996         家具.家用儿童帆布床和折叠床.试验方法         Furniture - Children's cots and folding cots for domestic use - Test methods
BS EN 747-1-1993         家具.家用床具.安全要求         Furniture - Bunk beds for domestic use - Safety requirements
BS EN 747-2-1993         家具.家用床具.试验方法         Furniture - Bunk beds for domestic use - Test methods
BS EN ISO 16000-10-2006         室内空气.对建筑产品和家具中挥发性有机化合物散发性的测定.散发试验管法         Indoor air - Determination of the emission of volatile organic compounds from building products and furnishing - Emission test cell method
BS EN ISO 16000-11-2006         室内空气.对建筑产品和家具中挥发性有机化合物散发性的测定.抽样、样本储藏和试验样本的准备         Indoor air - Determination of the emission of volatile organic compounds from building products and furnishing - Sampling, storage of samples and preparation of test specimens
BS EN ISO 16000-9-2006         室内空气.对建筑产品和家具中挥发性有机化合物散发性的测定.散发试验室法         Indoor air - Determination of the emission of volatile organic compounds from building products and furnishing - Emission test chamber method
CWA 14248-2001         funStep(家具产品和商业数据).funStep应用活动模型AAM         FunStep (furniture product and business data) - funStep application activity model - AAM
DD ENV 1178-1-1995         家具.家用儿童高座椅.第1部分:安全技术要求         Furniture. Children's high chairs for domestic use. Safety requirements
DD ENV 1178-2-1995         家具.家用儿童高座椅.第2部分:试验方法         Furniture. Children's high chairs for domestic use. Test methods
DD ENV 12520-2000         家用家具.座椅.机械和结构安全要求         Domestic furniture. Seating. Mechanical and structural safety requirements
DD ENV 12521-2000         家用家具.桌子.机械和结构安全要求         Domestic furniture. Tables. Mechanical and structural safety requirements
DD ENV 13759-2001         家具.座椅.活动沙发床向后靠和/或微倾机构以及操作机构的耐用性测定的试验方法         Domestic furniture. Seating. Test method for the determination of the durability of reclining and/or tilting mechanisms and operating mechanisms for convertible sofa beds
DD ENV 581-2-2000         户外家具.野营、家用和订做的座椅和桌子.座椅的机械安全要求和试验方法         Outdoor furniture. Seating and tables for camping, domestic and contract use. Mechanical safety requirements and test methods for seating
发表于 2010-3-21 22:24:05 | 只看该作者
只有这些没什么用处啊,发点详细测试方法上来。
发表于 2010-3-28 03:36:32 | 只看该作者
这些一般没用了。必须是详细的内容了
GMT+8, 2026-10-20 00:38 , Processed in 0.053934 second(s), 18 queries , Gzip On.
