查看: 3014|回复: 12
塑料检验及知识
发表于 2007-8-12 20:56:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
ccurate die casting 精密压铸
powder forming 粉末成形
calendaring molding 压延成形
powder metal forging 粉末锻造
cold chamber die casting 冷式压铸
precision forging 精密锻造
cold forging 冷锻
press forging 冲锻
compacting molding 粉末压出成形
rocking die forging 摇动锻造
compound molding 复合成形
rotary forging 回转锻造
compression molding 压缩成形
rotational molding 离心成形
dip mold 浸渍成形
rubber molding 橡胶成形
encapsulation molding 注入成形
sand mold casting 砂模铸造
extrusion molding 挤出成形
shell casting 壳模铸造
foam forming 泡沫成形
sinter forging 烧结锻造
forging roll 轧锻
six sides forging 六面锻造
gravity casting 重力铸造
slush molding 凝塑成形
hollow(blow) molding 中空(吹出)成形
squeeze casting 高压铸造
hot chamber die casting 热室压铸
swaging 挤锻
hot forging 热锻
transfer molding 转送成形
injection molding 射出成形
warm forging 温锻
investment casting 精密铸造
matched die method 对模成形法
laminating method 被覆淋膜成形
low pressure casting 低压铸造
lost wax casting 脱蜡铸造
matched mould thermal forming 对模热成形模
[ 本帖最后由 john2005 于 2007-3-2 10:22 编辑 ]
模具词汇英语翻译(成形不良用语)
aberration 色差
bite 咬入
blacking hole 涂料孔(铸疵)
blacking scab 涂料疤
blister 起泡
blooming 起霜
blow hole 破孔
blushing 泛白
body wrinkle 侧壁皱纹
breaking-in 冒口带肉
bubble 膜泡
burn mark 糊斑
burr 毛边
camber 翘曲
cell 气泡
center buckle 表面中部波皱
check 细裂痕
checking 龟裂
chipping 修整表面缺陷
clamp-off 铸件凹痕
collapse 塌陷
color mottle 色斑
corrosion 腐蚀
crack 裂痕
crazing 碎裂
crazing 龟裂
deformation 变形
edge 切边碎片
edge crack 裂边
fading 退色
filler speak 填充料斑
fissure 裂纹
flange wrinkle 凸缘起皱
flaw 刮伤
flow mark 流痕
galling 毛边
glazing 光滑
gloss 光泽
grease pits 污斑
grinding defect 磨痕
haircrack 发裂
haze 雾度
incrustation 水锈
indentation 压痕
internal porosity 内部气孔
mismatch 偏模
mottle 斑点
necking 缩颈
nick 割痕
range peel 橘皮状表面缺陷
overflow 溢流
peeling 剥离
pit 坑
pitting corrosion 点状腐蚀
plate mark 模板印痕
pock 麻点
pock mark 痘斑
resin streak 树脂流纹
resin wear 树脂脱落
riding 凹陷
sagging 松垂
saponification 皂化
scar 疤痕
scrap 废料
scrap jam 废料阻塞
scratch 刮伤/划痕
scuffing 深冲表面划伤
seam 裂痕
shock line 模口挤痕
short shot 充填不足
shrinkage pool 凹孔
sink mark 凹痕
skin inclusion 表皮摺叠
straightening 矫直
streak 条状痕
surface check 表面裂痕
surface roughening 橘皮状表皮皱摺
surging 波动
torsion 扭曲
warpage 翘曲
waviness 波痕
webbing 熔塌
weld mark 焊痕
whitening 白化
wrinkle 皱纹
john2005
保龙一族
模具词汇英语翻译(塑胶原料)
acrylic 压克力
casein 酪素
cellulose acetate 醋酸纤维素CA
cellulose acetate butyrate 醋酸丁酸纤维素CAB
composite material 复合材料
cresol resin 甲酚树脂CF
dially phthalate 苯二甲酸二烯丙酯
disperse reinforcement 分散性强化复合材料
engineering plastics 工程塑胶
epoxy resin 环氧树脂EP
ethyl cellulose 乙基纤维素
ethylene vinylacetate copolymer 乙烯-醋酸乙烯EVA
ethylene-vinlacetate copolyme 醋酸乙烯共聚物EVA
fiber reinforcement 纤维强化热固性/纤维强化复合材料
high density polyethylene 高密度聚乙烯HDPE
high impact polystyrene 高冲击聚苯乙烯HIPS
high impact polystyrene rigidity 高冲击性聚苯乙烯
low density polyethylene 低密度聚乙烯LDPE
melamine resin 三聚氰胺酚醛树脂MF
nitrocellulose 硝酸纤维素
phenolic resin 酚醛树脂
plastic 塑胶
polyacrylic acid 聚丙烯酸PAP
polyamide 耐龙PA
polybutyleneterephthalate 聚对苯二甲酸丁酯PBT
polycarbonate 聚碳酸酯PC
polyethyleneglycol 聚乙二醇PFG
polyethyleneoxide 聚氧化乙烯PEO
polyethyleneterephthalate 聚乙醇对苯PETP
polymetylmethacrylate 聚甲基丙烯酸甲酯PMMA
polyoxymethylene 聚缩醛POM
polyphenylene oxide 聚硫化亚苯
polyphenyleneoxide 聚苯醚PPO
polypropylene 聚丙烯PP
polystyrene 聚苯乙烯PS
polytetrafluoroethylene 聚四氟乙烯PTFE
polythene 聚乙烯PE
polyurethane 聚氨基甲酸酯PU
polyvinylacetate 聚醋酸乙烯PVAC
polyvinylalcohol 聚乙烯醇PVA
polyvinylbutyral 聚乙烯醇缩丁醛PVB
polyvinylchloride 聚氯乙烯PVC
polyvinylfuoride 聚氟乙烯PVF
polyvinylidenechloride 聚偏二氯乙烯PVDC
prepolymer 预聚物
silicone resin 矽树脂
thermoplastic 热塑性
thermosetting 热固性
thermosetting plastic 塑胶
unsaturated polyester 不饱和聚酯树脂
john2005
保龙一族
模具词汇英语翻译(射出成形)
activator 活化剂
bag moulding 气胎施压成形
bonding strength 黏合强度
breathing 排气
caulking compound 填隙料
cell 气孔
cold slug 半凝式射出
colorant 著色剂
color matching 调色
color masterbatch 色母料
compound 混合料
copolymer 共聚合体
cull 残料废品
cure 凝固化
cryptometer 不透明度仪
daylight 开隙
dry cycle time 空料试车周期时间
ductility 延性
elastomer 弹性体
extruded bead sealing 压出粒涂层法
feed 供料
filler 充填剂
film blowing 薄膜吹制法
floating platen 活动模板
foaming agent 发泡剂
gloss 光泽
granule 颗粒料
gunk 料斗
hot mark 热斑
hot stamping 烫印
injection nozzle 射出喷嘴
injection plunger 射出柱塞
injection ram 射出冲柱
isomer 同分异构物
kneader 混合机
leveling agent 匀涂剂
lubricant 润滑剂
matched die method 配合成形法
mould clamping force 锁模力
mould release agent 脱模剂
nozzle 喷嘴
oriented film 取向薄膜
parison 吹气成形坏料
pellet 粒料
plasticizer 可塑剂
plunger 压料柱塞
porosity 孔隙率
post cure 後固化
premix 预混料
purging 清除
reciprocating screw 往复螺杆
resilience 回弹性
resin injection 树脂射出法
rheology 流变学
sheet 塑胶片
shot 注射
shot cycle 射出循环
slip agent 光滑剂
take out device 取料装置
tie bar 拉杆
toggle type mould clamping system 肘杆式锁模装置
torpedo spreader 鱼雷形分流板
transparency 透明性
void content 空洞率
发表于 2007-8-13 09:04:18 | 只看该作者
谢谢楼主了,辛苦了,大家感谢你
发表于 2008-3-25 19:34:23 | 只看该作者
什麽都不说了.顶
发表于 2008-3-26 09:43:00 | 只看该作者
ding
发表于 2008-3-26 13:36:06 | 只看该作者
很好的免费资料!谢谢分享!
xubaolei 该用户已被删除
发表于 2008-6-10 14:50:45 | 只看该作者
呵呵。。。。。。。。。。。
发表于 2008-8-9 19:28:47 | 只看该作者
不错,支持一下
发表于 2009-8-10 20:39:01 | 只看该作者
so many thanks
发表于 2010-2-26 10:45:31 | 只看该作者
辛苦了,支持一下。
发表于 2010-3-1 09:38:55 | 只看该作者
不错,辛苦了。
GMT+8, 2026-10-20 00:03 , Processed in 0.031674 second(s), 19 queries , Gzip On.
