查看: 1313|回复: 6
transit testing 运输测试
发表于 2007-12-7 09:17:12 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
运输测试包括了震动测试和跌落测试。大家看到的一般都是简洁版的,现在附上扩展的,大家就可以知道测试的时间和转速是怎么确定得来的。文件为英文版的。
Transit Testing
Sequence
Test Category
Test Type
Test Level
1
Vibration
Fixed Displacement
1in.(25mm) peak to peak at a freq. to be determined
2
Shock
Drop
Height varies with packaged-product weight
Vibration testing process:
Sequence
Instruction
1
Check the quality of the product prior to performing the test, this is to make sure that the defect are due to the drop test and not the workmanship.
2
Face 3 rests on the platform
3
Start vibrating at 1 inch (25mm) total displacement at the machine’s lowest frequency
4
Increase the frequency until the packaged-product begins to momentarily leave the surface of the platform and a metal shim can be intermittently moved between the bottom of the longest dimension of the package-product and the surface of the platform.
5
Determine the test duration in minutes using following formula.
                                              14,200 Vibratory Impacts
Test Duration in Minutes= ------------------------------------------------------------------
                     Cycles Per Minute (CPM) or 【Cycles Per Second (Hz) x 60】
6
Begin the vibration duration.
7
If not using a vertical linear motion on the vibration system, perform a horizontal rotation of
90
° or 180°at half way through the vibration duration.
8
Complete the vibration duration and inspect samples.
A restraining device or devices shall be used with the vibration test system to:
Prevent the test specimen from moving off the platform and
Maintain test orientation of the packaged-product, but
The device or devices shall not restrict the vertical motion of the test specimen during the test.
 楼主| 发表于 2007-12-7 09:19:02 | 只看该作者
Drop testing process:
Packaged-Product Weight
Drop Height
Equal to or greater than (kg)
But Less than
(kg)
Free Fall
(mm)
0
10
760
10
19
610
19
28
460
28
45
310
45
68
200
Conduct drop test in following order
Sequence
Orientation
Specific face, edge or corner
1
Corner 2-3-5
Most fragile face, it must be at the edge of joint
2
Edge 3-5
Shortest edge radiate from that corner
3
Edge 2-5
Medium edge radiate from that corner
4
Edge 2-3
Longest edge radiate from that corner
5
Face 6
The one of two smallest faces
6
Face 5
The other face of the smallest faces
7
Face 2
The other face of two medium faces
8
Face 4
The other face of the medium face
9
Face 1
The one of two largest faces
10
Face 3
The other one of the largest face
 楼主| 发表于 2007-12-7 09:24:36 | 只看该作者
还有一张图片了介绍各面,各角,各线。但是图片放不上来。
发表于 2007-12-7 23:35:06 | 只看该作者
不错,值得一下,特别是运输测试
发表于 2007-12-8 08:55:15 | 只看该作者
不错,值得推荐一下,特别是运输测试
发表于 2014-9-18 05:55:52 | 只看该作者
学习一下!
发表于 2014-10-30 12:47:40 | 只看该作者
谢谢啦,有图就更实用了。
GMT+8, 2026-10-18 03:04 , Processed in 0.084824 second(s), 17 queries , Gzip On.
