查看: 9196|回复: 50
家具工厂机器设备大全
发表于 2007-11-10 19:42:55 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
1. 横切锯(Cutoff Saw)
2. 面刨(Facer)
手压刨(Hand Jointer)
3. 刨木机(Planer)
单面刨(Single Planer)
双面刨(Double Planer)
上下刨(Facer/Planer)
4. 刨(修)边设备(Lumber Edge Jointing Equipment)
Glue Joint Edging Saw
胶合平刨机(Glue Jointer)
5. 纵切锯(Rip Saws)
直线纵切锯(Straight-Line Ripsaw)
多片锯(Gang Ripsaw)
6. 胶合设备(Equipment for Edge & Face Gluing)
胶合回转机(Glue Reel,Clamp Carrier)
Batch Press
连续式拼板机(Continuous Edge Gluer)
7. 合板设备(Plywood Equipment)
薄片裁切机(Veneer Clippers)
薄片拼接机(Veneer Splicers)
布胶机(Glue Spreaders)
热压机(Hot Presses)
8. 裁板设备(Panel Cutting Equipment)
Panel Cut-Up Saws
Panel Saws for Trimming
9. 四面刨(Moulder)
传统式四面刨(Conventional Moulder)
模块设计四面刨(Feed-Through Moulder-Design Moulder)
10. 双端裁剪机(Double End Tenoner)
11. 万能锯(Variety Saw)
12. 带锯与再锯机(Band Saws & Resaws)
带锯机(Bandsaws)
自动带锯机(Auto. Bandsaws)
再锯机(Resaws)
13. 铣剖机与靠模成形机(Shapers & Profilers)
单轴铣剖机(Single-Spindle Shapers)
双轴铣剖机(Double-Spindle Shapers)
自动铣剖机及靠模成形机(Auto.Shapers&Profilers)
Linear Feed Profiler
Fixed-Spindle Rotary Shapers and Profilers
Whitney-Type Shaper
A & B Auto. Shaper
Rotary-Table Shapers and Profilers
Double-Spindle Copying Shaper
14. 路达机(Routers)
传统型(Conventional Pin Router)
倒立型(Inverted Router)
数控型(Numerically Controlled Routers)
15. 鸠尾榫机(Dovetail Machines)
鸠尾榫机(Dovetailer)
自动鸠尾榫机(Auto. Dovetailer)
法式鸠尾榫机(French Dovetailer Machines )
16. 雕刻机(Wood Carving Machines)
路达机(Router)
单轴雕刻机(Spindle Carver)
多轴雕刻机(Multiple-Spindle Carver)
热压花机(Embossing Presses)
17. 角凿机(Mortisers)
空心角凿机(Hollow Chisel Mortiser)
振荡凿孔机(Oscillating Chisel Mortiser)
路达机(Router)
18. 钻孔机(Boring Machines)
单轴钻孔机(Single-Spindle Boring Machines)
垂直多轴钻孔机(Verticle Multiple-Spindle Machines)
水平双轴钻孔机(Horizontal Double-Spindle Machine)
簇头(Cluster Heads)
钻孔机(Fixed-Center Boring Machine)
非平行钻孔(Nonpallel Boring)
点到点钻孔(Point-To-Point Boring)
床架钻孔作槽机(Bed Lock Machines)
19. 制椅设备(Equipment for Seating Furniture)
圆榫加工刀头(Chucking Heads)
双端横切及钻孔机(Double-End Trim and Boring Machine)
单端横切及圆榫机(Single-End Cutoff Boring or Chucking Machine)
双端横切、钻孔、注胶及插木钉机(Feed_Through Trim and Bore Machine)
水平锯(Leveling Saw)
鞍座刨(Saddle Seat Cutting)
椅座钻孔机(Seat Boring Machines)
椅后脚多轴钻孔机(Back Post Multiple Boring Machine)
20. 车床(Wood Turning Lathes)
单点车床(Single-Point Lathes)
背刀车床(Back-Knife Lathes)
形削车床(Shaping Lathes)
仿形车床(Copying Lathes)
21. 平面砂光机(Flat Sanding)
宽带砂光机(Wide-Belt Sanders)
多鼓砂光机(Multiple-Drum Sanders)
砂刨机(Abrasive Planers)
Hand Block
Sanders Hand Lever Stroke Sander
Power Stroke Sander
Hand -Fed Sanders
Semi-Automatic Sanders Automatic Sanders
Cross-Belt/Wide-Belt Combination Polisher
22. 曲面砂光机(Sanding Edges & Mouldings)
Edge Sander
Vertical Belt Variety Sander
Scroll Sander
Mould Sanding
Hand Block Sanding
Stationary Formed-Block Sanding
Automated_Feed Moulding Sanders for Panel Edges
Pneumatic-Drum Sanders
Spool and Wrap Sanders
Rotating Abrasive Brushes and Wheels Sandind Carvings Sanding Turnings
Copy-Shape Sanding
Reciprocating Sanding of Mouldings
23. 装配设备(Assembly Equipment)
胶枪(Glue Gun)
布胶器(Spreaders)
木钉涂胶插入机(Dowel Gluing and Driving Machine)
夹具(Clamps)
平面夹具(Clamps for Flat Subassemblies)
高周波夹具(High-Frequency Electric Assembly Fixtures)
立体装配夹具(Clamps for Final Assembly)
旋动箱体夹具(Revolving Case Clamp)
旋动箱体夹具(Stationary Case Clamping Machine)
椅子夹具(Chair Clamp)
抽屉夹具(Drawer Clamp)
床与镜框夹具(Bed or Mirror Frame Clamp)
打钉机(Fastening Machines)
发表于 2007-11-11 21:02:19 | 只看该作者
很好,学习学习。~~~~~~~~~
发表于 2007-11-16 23:07:27 | 只看该作者
果真很全啊,开眼界了。谢谢。
发表于 2007-11-19 14:51:55 | 只看该作者
全面!完整,谢谢!
发表于 2007-11-19 21:16:47 | 只看该作者
i不错啊!
发表于 2007-12-28 16:51:31 | 只看该作者
难得啊, 学习中谢谢了!
发表于 2007-12-30 20:18:55 | 只看该作者
很完整
发表于 2008-1-12 00:28:23 | 只看该作者
以前他认得我,可是我却不认得他,惭愧啊
发表于 2008-1-23 10:59:21 | 只看该作者
牛,谢谢楼主无私奉献,大家向他学习!
发表于 2008-2-3 11:02:47 | 只看该作者
很好,有时间我再来温习.
GMT+8, 2026-10-19 23:22 , Processed in 0.038297 second(s), 17 queries , Gzip On.
