查看: 734|回复: 8
专业提供福建地区验厂验货监柜服务
发表于 2012-10-3 11:45:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
专业提供福建地区验厂验货监柜服务
合作项目-提供首件确认、大货过程控制、出货前检验、监柜、全检、返修、验厂等服务。
产品区域-机械五金产品、塑胶产品、木制+钢制家具、卖场货架、运动器材、餐具、服装、鞋、包袋、床上纺织用品,石材、玻璃、陶瓷、卫浴产品、汽配件、水泵、阀门、活塞、电机、铁艺、布艺、树脂彩绘工艺品、纯密胺产品、户外休闲产品、洋伞、玩偶、圣诞礼品、家用日用品、文具、充电器、剃须刀、移动存储器、电风扇、开关、磁铁、荧光棒、办公用品等.
熟悉产品品质要求和检验、测试要点,工作细致严谨、责任心强,报告清晰完整。自带电脑、相机、检验工具,一般情况下可以在验货或验厂当日提供详细的英文报告。
英语口语流畅,验货过程中可与您及您的客人保持顺畅沟通。
I’m a professional freelance HubertHu, who ever experience 12 years on quality control and has solid industryexperiences on product inspection and factory running. I provide variousproduct inspection service and factory audit for the client from China and otherregion. I speak English so I can keep smooth communication with you and yourclient during service.
First Article Approval
Offer FirstArticle Approval Service to client according to their confirmed staffswhich including but not limited engineering drawings, approved original samplesand so on. This service may give you reference with the process capability ofthe manufacturer and help you to develop new project in your business. We willsend detailed report with pictures to you within 12 hours once this step getsdone.
Pre-production Inspection
This Pre-productionInspection Service will perform a production sample and raw materialchecking process as your instruction at the very beginning of mass production,your additional requirements will be concerned and applied to our service. Thisservice will make sure all necessary parts are available and correct beforemass production and will see a sample built under a real manufacture condition.You will receive a quick report within 12 hours once the inspection work getscompleted.
In-production Inspection
If you’d like a people look into yourproducts during the production in factory this just for you. We will arrange QCpeople work in your appointed factory if you refer to In-production InspectionService. Based on your products we will arrange QC with relative industrybackground to help you. We will keep eyes in the factory and make inspectionaccording to your specification and requirement. You will receive a dailyreport based on the quality and progress following.
Final Random Inspection
If you want to verify your productsbefore container loading we can perform a Final Random Inspection which commonlyconsisted of visual inspection, dimension check, test, package, marking,quantity and so on. This inspection implemented based on samples selectedaccording to defined sampling procedures and carried out under your supplier’spermission or accompanied by them. A final inspection report with details willbe submitted to you within 24 hours.
Container Loading Supervision
Loading Supervision will perform aservice to care below concerns:
a) Container condition check beforeloading.
b) Damage control.
c) Monitor therationality of arrangement of space.
d) Quantity countingall through loading operation.
e) Review, takepictures before, during and after loading.
f) Packing List andSeal checking.
Focusedon:
Machinery、Metal、Plastic、Furniture、Shoes、Sports、Cutlery、Bath、Wood、Glass、Marble、Valves、Pumps、Householdproduct、handcrafts、Cloth、shoes、stationery、light.
Hubert Hu
TEL-13600945875
Huberthuxm@gmail.com
QQ: 457963792
SKYPE: Hubertxm
发表于 2012-10-3 11:59:49 | 只看该作者
发表于 2012-10-4 11:12:06 | 只看该作者
我很闲哦,有需要福建的我可以帮忙哦,同时支持一下楼主。QQ:381283022
发表于 2012-10-4 19:57:35 | 只看该作者
支持!
发表于 2012-10-4 21:32:14 | 只看该作者
发表于 2012-10-4 22:16:13 | 只看该作者
楼主 很专业 啊  顶一个 呵呵
发表于 2012-10-5 07:09:11 | 只看该作者
发表于 2012-10-5 21:45:32 | 只看该作者
支持楼上的
发表于 2012-10-6 10:14:40 | 只看该作者
支持,支持,强烈支持。。。
GMT+8, 2026-10-29 04:43 , Processed in 0.032919 second(s), 21 queries , Gzip On.
