查看: 1625|回复: 11
山东的朋友谁能验以下产品并请报价
发表于 2012-9-13 07:32:43 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
验货地点在德州
Item 1.
HDPE sheet, liner of thickness 3mm to be placed over clay subgrade at landfill site.
Density of 0.95 gm/cm3, water absorption of 0.01% and ultimate tensile strength of 25MPa.
Rolls 4x100m
Qty 36,000.00 m2
Item 2.
Woven Geotextile, weight: 250g/m2, rolls of 4m x 100m for landfill site.
It should be previous geotextile of woven polypropylene stabilized against short term UV degradation and against long term thermo-oxidation.
It shall be inert to chemicals commonly encountered in leachate and natural soils.
It must be non-biodegradable, resistant to most soil chemicals and bacteria, unaffected by acids and alkaline within a pH range of 3-12.
Specifications:
a)Tensile strength to ISO 5081 standard but not less than 35Kn
b)UV resistance after 500hrs of 70%
c)Water flow rate 36 litres/min/m2 OR 4 gal(US)/min/sqft.
e)Puncture resistance (CBR) test greater than 5Kn
Rolls 4x100m
Qty 25,600.00 m2
Item 3.
LDPE sheet, plastic liner, 3mm thick, highly flexible.
Resistance to corrosive environment to reduce water as per conformity BS EN ISO 11963:1996 or equivalent.
Rolls 4x100m
Qty 4,800.00 m2
 楼主| 发表于 2012-9-13 07:34:09 | 只看该作者
补充一下,由于较忙请将报价及联系方式发送到QQ邮箱:106778070, 山东地区的QC优先
发表于 2012-9-13 08:26:09 | 只看该作者
支持
发表于 2012-9-13 08:46:40 | 只看该作者
支持
发表于 2012-9-13 09:04:18 | 只看该作者
路过的
发表于 2012-9-13 09:22:21 | 只看该作者
支持  有点远
发表于 2012-9-13 10:33:11 | 只看该作者
支持
 楼主| 发表于 2012-9-13 11:54:55 | 只看该作者
谁能验请报价,时间还未定
发表于 2012-9-13 12:38:36 | 只看该作者
浙江金华支持一个
发表于 2012-9-13 21:16:02 | 只看该作者
如果需要广东这边兼职验货服务,请联系我
QQ:1728755648
GMT+8, 2026-11-7 12:26 , Processed in 0.034878 second(s), 18 queries , Gzip On.
