查看: 1009|回复: 6
求关于划痕方面的标准
发表于 2012-5-28 16:14:14 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
求关于划痕方面的标准,谢谢大虾指点
 楼主| 发表于 2012-5-28 16:17:19 | 只看该作者
自己顶一下
发表于 2012-5-28 21:36:18 | 只看该作者
1-2mm算MInor .2mm以上算Major
发表于 2012-5-28 22:01:19 | 只看该作者
原帖由 Denny.Xie 于 2012-5-28 21:36 发表
是指长度吗?
发表于 2012-5-28 22:45:26 | 只看该作者
Acceptable Tolerances: Major defect: More than 1/2" in length for flat scratch, or more than 1/4” in length for
depth and width scratch, equal or more than 3 scratches on the whole outside surface; Minor defect: Between 1/4“
to 1/2” in length for flat scratch and less than 3 scratches, or between 1/8” to 1/4” in length for depth and width
scratch and less than 3 scratches on the whole outside surface. The Major acceptable tolerances on
outside/visible area can be considered as minor defect on inside/hidden part; The Minor acceptable tolerances on
outside/visible area can be considered as acceptable on inside/hidden area.
How to Measure method: The scratch length measurement should follow the curve, and not straight measurement. That is to say, measure the curve length along with the scratch instead of the beeline length from the start point to the end point. The width and depth is judged by QC’s subjectivity.
发表于 2012-5-29 17:30:01 | 只看该作者
看实际情况,依据实际产品,杂货超过2MM就是Major工厂都不用做了
发表于 2012-5-30 15:13:28 | 只看该作者
GMT+8, 2026-10-25 10:05 , Processed in 0.174758 second(s), 18 queries , Gzip On.
