查看: 1721|回复: 7
Hi-pot+voltage.xls
发表于 2012-5-8 00:25:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Hi-pot voltage (European) of labortaory test and inspection check (Routine / inspection)
Routine check (1s per point)Inspection check (1s per point)
No.Standard refrelated product catClass IClass IClass II
160065Audio product15003300
260335Household accessories1000VAC (30mA)2500VAC (30mA)
1500VDC (30mA)3750VDC (30mA)
360950IT product (telephone or office equipment)1500VAC3000VAC
2100VDC4200VDC
For telephone: extra test point is required - Tip / Ring to1500 (base)1800 (Corded phone-handset)
460745Handheld electric and battery tools15004300
561029transportable electric tools1000 (3s 5mA)2500 (3s 5mA)
660598Luminaires1500VAC (5mA)1500VAC (5mA)
2150VDC (5mA)2150VDC (5mA)
760730Automatic electrical control for ousehold (e.g. thermostat control, timer)15004300
861558Transformer or AC adaptor24004300
Note:
If the AC/DC adaptor is used as an accessory for the whole product, we should use the related product standard to perform the Hi-pot check.
e.g. Radio powered by a separate AC/DC adaptor (Class II), IEC60065 (Audio product) - 3300VAC 1s.
e.g. Paper shredder powered by a separate AC/DC adaptor (Class II), IEC 60950 (IT product) - 3000VAC 1s.
e.g. Transformer or AC adaptor (Class II),
the product is the transformer or AC adaptor only, IEC 61558 - 4300V 1s.
Since the Hi-pot test of the below prodcuts depends on their diifferent types (not Class I and Class II), they are listed in indiviual tables.
960968Self-ballasted lamps (Energy saving lamp)Routine check (1s per point)Inspection check (1s per point)
Type BV (100~120V)Type HV (220~250V)Type BV (100~120V)Type HV (220~250V)
15004300
For DMM with measuring voltage between 600 to 1000VRoutine check (1s per point)Inspection check (1s per point)
1061010Laboratory equipment (e.g. DMM)CAT II DMMCAT III DMMCAT II DMMCAT III DMM
58007500
 楼主| 发表于 2012-5-8 00:28:56 | 只看该作者
Checklist+(Portable+CD+cassette+player).doc
TEST REPORT
IEC  60065:2001 and EN 60065:2002
Audio, video and similar electronic apparatus
Safety requirements
Report Reference No.        :
Tested by (+ signature)        :
Approved by (+ signature)        :
Date of issue        :
Contents        :        Pages  to  for IEC60065:2001/EN60065:2002 TRF including Group differences + National differences for CENELEC countries (EN60065:2002)
Appendix A   to A     for National difference of
Appendix A   to A   for Clause 8 and 9 of
IEC60825-1:1993+A1:1997+A2:2001
Appendix A   to A   for Photo Pages
Testing laboratory Name        :        Intertek Testing Services Hong Kong Ltd.
Address        :        2/F., Garment Centre, 576 Castle Peak Road, Kowloon, Hong Kong
Testing location         :        CBTL 0        CCATL 0        SMT 0        TMP 0
Testing location        :        as above
Client Name        :
Address        :
Standard        :        IEC 60065:2001 and EN 60065:2002
Test procedure         :        CB
Non-standard test method        :        N.A.
Test Report Form/blank test report
Test Report Form No.        :        IECEN60065D
Master TRF        :        Dated 2003-01
Copyright @ 2002 IEC System for Conformity Testing and Certification of Electrical Equipment (IECEE), Geneva, Switzerland.  All rights reserved.
This publication may be produced in whole or in part for non-commercial purposes as long as the IECEE is acknowledged as copyright owner and source of the material.  IECEE takes no responsibility for and will not assume liability for damages resulting from the reader’s interpretation of the reproduced material due to its placement and context
Test item Description        :
Trademark        :
Model and/or type reference        :
Manufacturer        :
Rating(s)        :
 楼主| 发表于 2012-5-8 00:30:09 | 只看该作者
lcd report
INSPECTION REPORT
APPLICANT:                DATE:         Sep 02, 2004
PRODUCT (assemble)                GIFT BOX
DESCRIPTION         :        17” LCD MONITOR
BUYER        :
SUPPLIER        :        .
ORDER NO.        :        8640558
ART NO.        :        696550
SERIAL NO.        :
SUPPLIER ART NO.        :        --
COLOR        :        Black and Silver
DATE OF INSPECTION        :        Aug 31, 2004
PLACE OF INSPECTION        :        CHINA (SHANGHAI)
CONCLUSION :
THE INSPECTION RESULTS OF THE ABOVE MENTIONED MERCHANDISE WERE FOUND AS FOLLOWS:
INSPECTION CRITERIA        * RESULT
A) QUANTITY AVAILABLE        Conformed
B) PRODUCT DESCRIPTION, STYLE AND COLOUR        No sample for comparison
C) WORKMANSHIP        Conformed
D) DATA MEASUREMENT        As per actual finding
E) FORM OF PACKAGING        No requirement
F) SHIPPING MARK        No requirement
SUMMARY RESULT                CRITICAL        MAJOR        MINOR
WORKMANSHIP        NO. OF DEFECT ALLOWED :        0        2        5
        TOTAL FOUND :        0        0        2
OVERALL INSPECTION RESULT        :        Conformed        to applicant’s requirement.
* FOR DETAILS, PLEASE REFER TO THE ATTACHED INSPECTION REPORT.
INSPECTION REQUIREMENT        :        FINAL RANDOM INSPECTION
                INSPECTION STANDARD ADOPTED:        BS6001-1:1999
                Single Sampling Plan For Normal Inspection General Level I
                ACCEPTABLE QUALITY LEVEL (AQL) FOR:
CRITICAL NONCONFORMITY (DEFECTIVE)        :        Not Allowed on the inspected samples
MAJOR NONCONFORMITY (DEFECTIVE)        :        1.5
MINOR NONCONFORMITY (DEFECTIVE)        :        4.0
INSPECTION RESULTS:
THE INSPECTION RESULTS WERE FOUND AS FOLLOWS :
A)        QUANTITY AVAILABLE:
ORDER QUANTITY        ACTUAL AVAILABLE
QUANTITY (SHIPMENT)        NOT FINISHED QUANTITY        SAMPLING SIZE FROM
                PACKED        NOT PACKED                PACKED QUANTITY        NOT PACKED QUANTITY
NO. OF PIECE        1344        1344        0        0        50        0
NO. OF CARTON        1344        1344        0        0        50
CARTON NO. WAS NOT ASSIGNED YET.
B)        PRODUCT DESCRIPTION, STYLE AND COLOUR:
CHECK AGAINST PO
-        The inspected samples were fond similar to the description of PO.
CHECK AGAINST SAMPLES
-        NO SUBMITTED SAMPLE WAS PROVIDED BY APPLICANT OR VENDOR FOR STYLE & COLOUR COMPARISON
CHECK THE INSTRUCTION MANUAL :
-        Since the instruction manual is not printed in English version, therefore, verification is not conducted.
-        No instruction manual is included.
C)        WORKMANSHIP :
DETAILS OF NONCONFORMITY (DEFECTIVE):        CRITICAL        MAJOR        MINOR
Dirt on housing                -        -        1
Fingerprint on housing                -        -        1
ACTUAL FINDING :        0        0        2
ALLOWED :        0        2        5
Discrepancy was found refer to note point 8.
发表于 2012-5-8 09:42:36 | 只看该作者
路过··························
发表于 2012-5-8 10:30:38 | 只看该作者
谢谢分享,不过论坛里早有类似的了。
发表于 2012-5-8 12:09:34 | 只看该作者
谢谢.....
发表于 2012-5-8 12:37:48 | 只看该作者
LZ 还是整一附件吧,这样直接贴出来可能因为格式的原因显得排版比较乱
发表于 2012-6-27 19:58:02 | 只看该作者
如果能够整理一下可能会好点。
GMT+8, 2026-10-17 10:47 , Processed in 0.051630 second(s), 18 queries , Gzip On.
