查看: 530|回复: 2
请求帮助 非常急!!!
发表于 2012-2-27 11:32:01 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
麻烦各位大哥大姐翻译一下,
Shape 外形
Straight skirt with concealed plastic zip fastener on the left hip side
Darts
4 waist darts to allow for hips 腰部4褶
Pleat
Inverted box pleat at the back enough to allow easy movement
Pockets
5 double stitched belt loops onononValue="1" HasSpace="False" Negative="False" NumberType="1" TCSC="0">1cm width and 3 1/onononValue="2" HasSpace="False" Negative="False" NumberType="1" TCSC="0">2” length to accommodate 2 1/8 inch belt
Bottom
11/onononValue="2" HasSpace="False" Negative="False" NumberType="1" TCSC="0">2’ hand hemmed
谢谢
发表于 2012-2-27 11:32:09 | 只看该作者
Shape 外形
Straight skirt with concealed plastic zip fastener on the left hip side 直裙在左坐围侧骨有塑料隐形拉链
Darts
Pleat
有反面车盒褶,并能方便活动
Pockets
5 double stitched belt loops ononononononValue="1" 耳仔用双针面线
TCSC="0">1cm width and 3 1/ononononononValue="2" HasSpace="False" Negative="False" NumberType="1" TCSC="0">2” length to accommodate 2 1/8 inch belt
Bottom
11/ononononononValue="2" HasSpace="False" Negative="False" NumberType="1" TCSC="0">2’ hand hemmed
后面的完全不知道是什么了,期待高手上。
 楼主| 发表于 2012-2-27 11:32:18 | 只看该作者
Pockets :5 double stitched belt loops 1cm width and 3 1 length to accommodate 2 1/8 inch belt
Bottom:11 hand hemmed
GMT+8, 2026-11-5 14:45 , Processed in 0.372918 second(s), 19 queries , Gzip On.
