查看: 520|回复: 4
不好翻译,请帮忙译一下.多谢!
发表于 2012-2-27 10:42:54 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请看以下一句, 你能帮我一下吗?
shirring fulnes next to fullness@apex shirring. Keep same fullness but start 2" in from side seam / moving fullness towards apex . Ruffle @ midriff will be flat for this 2 target="_blank" >
我想知道APEX 指哪里呢?
谢谢你的解析,如果你知道.
JASMIN
发表于 2012-2-27 10:42:58 | 只看该作者
对不起, 上面的错码了, 不对,我再写一遍:
shirring fullness next to ss @underarm does not look good , also need more Ruffle@midriff will be flat for this 2 target="_blank" >
发表于 2012-2-27 10:43:02 | 只看该作者
There is wrong with my pc, sorry, the above is hard to understand. I will write again after i check again.
发表于 2012-2-27 10:43:08 | 只看该作者
shirring fullness next to side seam at underarm does not look good, Also need more
fullness at apex shirring. Keep same fullness but start shirring 2" in from side seam and
moving fullness towards apex. Ruffle at midriff will be flat for this 2" span.
发表于 2012-2-27 10:43:15 | 只看该作者
褶尖吧~
GMT+8, 2026-11-5 19:42 , Processed in 0.186412 second(s), 19 queries , Gzip On.
