查看: 561|回复: 3
Sewing method problem
发表于 2012-2-27 10:21:16 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
We add a loop label attached at the left bottom of Tee. Pls see attached picture for the shape of loop label.Now we are confused by the instruction of sewing method from the designer. It said that "Stitch should overlap label by 1/4" on both sides". The problem is that we can not understand where related to "both sides". Pls advise and thanks a lot.
附件
发表于 2012-2-27 10:21:22 | 只看该作者
Label每边要车过1/4"在衫身上,(如图示)
发表于 2012-2-27 10:21:25 | 只看该作者
此图意思是:
夹标夹好后,在标的上沿来回车1/4"的子口线,标的上下层是一次性车的!(就是所谓的both side )
发表于 2012-2-27 10:21:29 | 只看该作者
Thanks very much!
I informed the fty try to clean & finish with 1/8" label at both interior and exterior layer turn over down.Then run s/n at 1/4" away from the edge. Hope they can help finish.
Thanks for your suggestion again.
GMT+8, 2026-11-5 15:51 , Processed in 0.390470 second(s), 22 queries , Gzip On.
