查看: 447|回复: 1
女装背心
发表于 2012-2-23 21:50:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请高手帮忙:
1. merrow edge finsih ruffle edges flat. top ruffle set over under ruffle at notch. sandwich at center front in mock placket seam.
2. placket: 3/8" seam clean fin . on top of center front at notch w/edge stitch around. fin 7/8" buttons. sew on top at mark.
3. neck& armhole: 3/8"one needle cover stitch, double fold bind neck & armholes. follow spec.
4. side dart: single needle 1/2" pass punch hole.
5. waist: overlock join seam w/ 1/2" elastic,and fold down seam w/ 1/2"single needle top stitch
发表于 2012-2-23 21:50:28 | 只看该作者
1. merrow edge finsih ruffle edges flat. top ruffle set over under ruffle at notch. sandwich at center front in mock placket seam. 荷叶边锁边完成,荷叶顶边移到荷叶底边刀位处,夹在打拦筒骨的前中位。
2. placket: 3/8" seam clean fin . on top of center front at notch w/edge stitch around. fin 7/8" buttons. sew on top at mark. 筒: 3/8“反折完成。在前中顶记号处间边线一周。7/8” 处开钮。车至顶的记号处。
3. neck& armhole: 3/8"one needle cover stitch, double fold bind neck & armholes. follow spec. 领和夹圈: 3/8“单针间线。双折领和夹圈。跟尺寸。
4. side dart: single needle 1/2" pass punch hole. 侧褶: 单针 过穿孔1/2”
5. waist: overlock join seam w/ 1/2" elastic,and fold down seam w/ 1/2"single needle top stitch腰: 与1/2”橡巾锁边合缝,止口倒向下间1/2“单针面线。
GMT+8, 2026-11-6 03:22 , Processed in 0.167441 second(s), 19 queries , Gzip On.
