查看: 1958|回复: 13
史上最全的包装类产品中英文Checklist (免金币)- 如果喜欢,请给我一点金币吧!
发表于 2012-2-22 10:42:15 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
ITEM
项目
DEFECT DESCRIPTION
缺陷描述
DEFECT CLASSIFICATION
缺陷分类
Critical
致命
Major
主要
Minor
次要
A
Master Carton
外箱
Check at least square root of total carton quantity.
至少抽取总箱数开根号的数量
Actual packing quantity does not match the marking
实际包装数量和箱唛不符
X
Actual size does not match the marking (>5%)
实际尺寸和箱唛不符超过5%
X
Broken / damaged / deteriorative / wet
破裂、变形、变质、潮湿
X
Dirty / dusty / contamination > 5% of surface
脏、灰尘、污渍超过表面的5%
X
Marking/label is missing or incorrect
箱唛、标签缺失或错误
X
Barcodes are wrong or unscannable (check for 5 pcs)
条形码错误或无法识别(检查5个)
REJECT
退货
Too big so product can obviously move inside
太大以至于产品在里面会明显晃动
X
Too small so the opening has gap >5mm
太小以至于开口处有超过5mm的缝隙
X
Wrong material so as to affect product security during transit
材质错误可能导致产品在运输中受损
X
Opening not properly sealed with transparent tape
没有使用透明胶按要求封口
X
Wrong packaging direction of product inside carton
产品在外箱内的朝向不正确
X
B
Product
产品
Level II (min. 200 pcs)
二级抽样水准,至少200个
Broken / burr / sharp point may cause human injury
破裂、披锋、尖点可能导致人员伤害
X
Insect / worm on or inside product
昆虫、蠕虫在产品上或产品内
X
 楼主| 发表于 2012-2-22 10:42:40 | 只看该作者
Damaged / deteriorative / deformation
损坏、变质、变形                X
Magnetics malfunction so box opens by itself when catching the box in reversed direction
磁铁失效以至于抓住盒子倒置时盒子自行开启                X
        Fit check with full bottle, the bottle loosens out by itself when product declines at 45-degree angle
用满装的酒瓶做装配检查,产品倾斜45度角时,酒瓶自行脱落                X
        Zone A: Bump / dent (paper exposed) >2 sq.mm
A区: 碰伤、凹坑(纸张露底)超过2平方毫米                X
        Zone B: Bump / dent (paper exposed) >4 sq.mm
B区: 碰伤、凹坑(纸张露底)超过4平方毫米                X
        Zone C: Bump / dent (paper exposed) >6 sq.mm
C区: 碰伤、凹坑(纸张露底)超过6平方毫米                X
        Zone A: Bump / dent (paper exposed) within 1~2 sq.mm
A区: 碰伤、凹坑(纸张露底)在1~2平方毫米                        X
        Zone B: Bump / dent (paper exposed) within 2~4 sq.mm
B区: 碰伤、凹坑(纸张露底)在2~4平方毫米                        X
        Zone C: Bump / dent (paper exposed) within 3~6 sq.mm
C区: 碰伤、凹坑(纸张露底)在3~6平方毫米                        X
        Zone A: Scratched and paper exposed >3 mm
A区: 严重划伤(纸张露底)超过3毫米                X
        Zone B: Scratched and paper exposed >5 mm
B区: 严重划伤(纸张露底)超过5毫米                X
        Zone C: Scratched and paper exposed >8 mm
C区: 严重划伤(纸张露底)超过8毫米                X
        Zone A: Scratched and paper exposed within 2~3 mm
A区: 严重划伤(纸张露底)在2~3毫米                        X
        Zone B: Scratched and paper exposed within 3~5 mm
B区: 严重划伤(纸张露底)在3~5毫米                        X
        Zone C: Scratched and paper exposed within 5~8 mm
C区: 严重划伤(纸张露底)在5~8毫米                        X
        Zone A: Obvious scratch but paper not exposed >5 mm
A区: 明显划伤但纸张不露底超过5毫米                        X
        Zone B: Obvious scratch but paper not exposed >10 mm
B区: 明显划伤但纸张不露底超过10毫米                        X
        Zone C: Obvious scratch but paper not exposed >15 mm
C区: 明显划伤但纸张不露底超过15毫米                        X
        Zone A: Irremovable contamination >2 sq.mm
A区: 不可去除的污染超过2平方毫米                X
 楼主| 发表于 2012-2-22 10:43:03 | 只看该作者
Zone B: Irremovable contamination >4 sq.mm
B区: 不可去除的污染超过4平方毫米                X
        Zone C: Irremovable contamination >6 sq.mm
C区: 不可去除的污染超过6平方毫米                X
        Zone A: Irremovable contamination 1~2 sq.mm
A区: 不可去除的污染在1~2平方毫米                        X
        Zone B: Irremovable contamination 2~4 sq.mm
B区: 不可去除的污染在2~4平方毫米                        X
        Zone C: Irremovable contamination 3~6 sq.mm
C区: 不可去除的污染在3~6平方毫米                        X
        Zone A: Removable contamination >4 sq.mm
A区: 可去除的污染超过4平方毫米                X
        Zone B: Removable contamination >6 sq.mm
B区: 可去除的污染超过6平方毫米                X
        Zone C: Removable contamination >9 sq.mm
C区可去除的污染超过9平方毫米                X
        Zone A: Removable contamination within 2~4 sq.mm
A区: 可去除的污染在2~4平方毫米                        X
        Zone B: Removable contamination within 3~6 sq.mm
B区: 可去除的污染在3~6平方毫米                        X
        Zone C: Removable contamination within 6~9 sq.mm
C区可去除的污染在6~9平方毫米                        X
条形码错误或无法识别(检查5个)        REJECT
退货
        Major color-off for trade mark or key patterns
商标或主要图形存在明显色差                X
        Poor printing for key illustration or instruction
主要描述或说明存在印刷不良                X
发表于 2012-2-22 11:05:58 | 只看该作者
把附件传上来会更好。
发表于 2012-2-22 20:49:41 | 只看该作者
这样怎么看呀,弄个附件吧
发表于 2012-2-22 22:38:22 | 只看该作者
本身是个附件,您却复制出来了,完整一些,是好资料一定会有很多人给您加金币的
发表于 2012-2-23 18:59:20 | 只看该作者
发表于 2012-2-28 14:04:34 | 只看该作者
附件附件~
发表于 2015-12-26 23:31:37 | 只看该作者
good!
发表于 2016-7-7 11:12:38 | 只看该作者
goods
GMT+8, 2026-10-17 20:52 , Processed in 0.200443 second(s), 18 queries , Gzip On.
