查看: 405|回复: 1
紧急求助!急急急!
发表于 2012-2-15 22:41:51 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
100% cotton non iron suitable for making clergy shirts and blouses. Fabric is made from CPT40*CPT40 and adopt liquid ammonia and moist cure finish manner.The no iron grade is 3.5. 1000 Meters long 150 cm wide 求高手翻译这是什么面料??非常感谢!!
Quilted Batting Fabric. The inside lining should be 8 ounce polyester batting 求高手帮助.这是什么面料??
fabric under the band is 7.5in w/ 7.5 in liner to crotch seam and from crotch seam is also 7.5 up to top back of suit. there is a is no cup size fits 5.5 in piece of elastic attached in mid back that creates the scrunch butt..from size 32 A to 38 C or D.Also rhinestone square in mid of band on bottoms 这是泳衣裤,请高手帮忙,谢谢!!
发表于 2012-2-15 22:42:03 | 只看该作者
1.纯棉免烫面料,做牧师袍所用。经纬密为40*40,采取液氨整理和保湿处理,免烫度为3.5长1000米,门幅150cm.
2.夹有内衬的布吧:内衬为8盎司的涤纶丝。
牧师袍:
腰下到档点是7.5in(不含腰),前浪和后浪的内衬同样也是7.5in,后中安松紧带收褶,该批货的尺寸分配为从32A到38C或D,腰头中间镶成方块形的人造钻石,建议LZ多参考下客人的样衣。
附:液氨整理可以提高纯棉等天然纤维及其混纺产品的穿着服用性能,因结合树脂整理新技术而进一步提高免烫效果。
GMT+8, 2026-11-6 19:30 , Processed in 0.183287 second(s), 22 queries , Gzip On.
