查看: 1435|回复: 2
求内衣内裤各个部分的英文名
发表于 2012-2-15 20:36:19 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请问内衣内裤的各部分用英语分别怎么说啊?
很急 谢啦!!
发表于 2012-2-15 20:36:28 | 只看该作者
不知此帖是否有用?
中文 英文
1/2腰圍(放鬆度) 1/2 Waist length (relaxed)
  Waist on half
  1/2 Elasticatied waist
1/2腰圍平度 Waist flat on half
1/2腰圍(拉度) 1/2 Waist elastic strength
  1/2 Front waist elastic strength
  Waist stretch
  Waist extended
  Waist min stretch
1/2腳圍(下腳闊) 1/2 Bottom width
坐圍 Hip circle at top of leg
  Hip across top of leg
坐圍彎度 1/2 Hip (folded meas.)
1/2脾圍不計側繩 1/2 Thigh length excl. side elastic (side string)
1/2脾圍 1/2 Thigh (edge to edge)
  Leg on half
  Leg opening 1/2
1/2脾圍放鬆度 Leg flat - relaxed on 1/2
1/2脾圍放鬆度 1/2 Leg circumference
1/2脾圍拉度 Leg extended on 1/2
1/2脾圍拉度 Leg stretch
1/2脾圍(直度) Leg drop (straight line)
1/2脾圍穿起計右邊,放鬆度 1/2 Thigh length band - right side worn,relaxed
脾圍 Leg circle
脾圍放鬆度 Leghole relaxed
脾圍不連側繩 Thigh length (excl. waistband)
前幅褲脾長 Front leg length
前花邊長 Front EMB leg
前幅褲腳長連浪 Front leg flat incl. gusset
前褲腳長至骨位穿起計左邊 Back thigh length to seam - left side worn
後褲腳長至骨位穿起計左邊 Front thigh length to seam - left side worn
前中長彎度至花邊牙底 Front height - fold along edge / low scallop
前中長彎度(包褲頭丈巾) Front height - fold along edge (incl. Waistband)
  Frontlength incl. WB
前中長(彎度,連綑條)(連浪) Front height (curved,incl. binding)(incl. Crotch)
前中連底浪 Front length + Gusset length
前中長至前浪 C/F rise to front gusset
前中彎度 Centre front length (curve measured)
  Front rise cf to back gusset seam
  Front rise (folded meas.)
前中長包褲頭巾 CF to gusset (incl. W/B)
後中長變度 Back height - fold along edge
  Back rise including waist band
  Back rise (folded meas.)
後中長包褲頭巾 CB to gusset (incl. W/B)
後中長(彎度,連綑條) Back height (cureved,incl. binding)
後中長至前浪 Back rise to front gusset
後中長平度 Back centre length (plane)
後中丈巾長 Back string length cut at
後繩長(不連吊飾) Back length (excl. motif)
前浪闊 Front gusset width
前浪闊-沿骨度(連丈巾) Front crotch width - along seam (incl. Elastic)
前浪骨闊(連丈巾) Front crotch seam width (incl. Elastic)
前浪闊(後浪骨上10cm處) Front crotch width (10cm up from back crotch seam)
前浪闊(浪骨上11.5cm處) Front seat width (11.5cm up from crotch seam)
  Measure 11.5cm up from gusset
前浪闊褲頭落15cm處 Gusset width front 15cm fr to
前幅褲頭落11cm處 Across front 11cm fr to
後浪闊 Back gusset width
後浪闊-沿骨度(連丈巾) Back crotch width - along seam (incl. Elastic)
浪闊(度最窄位) Gusset width - narrowest
後幅闊浪上12cm處度 Back width 12cm abv gusset
後帶距(後幅最窄位) String width back
褲頭至後帶距長 Length to string
底浪長彎度 Crotch length - fold along edge
浪長 Gusset length
側骨 Side height / side depth
  Side height depth
  Sideseam fr. Upper edge
側骨包褲頭巾&綑條 Side length (incl. W/B & trim)
前幅褲頭長 Front panel width
前幅褲頭長(不連側繩) Front waist width (excl. side rope)
後幅褲頭長 Back panel width
褲頭繩長(打結後) Waist string length (after knots)
側繩長 Side waistband length / side string length
’’ Side rope length
兩側位丈巾長 Length of side rouleaus cut at
側丈巾帶長 Tanga sides finished
側繩長7cm回帶後 Side elastic length w/7cm loop
前側繩長(綁帶) Front side string length
後側繩長(綁帶) Back side string length
褲側綁帶長 Side strap length
前帶長(穿起計左邊) Front belt length (left side as worn)
前帶長(穿起計右邊) Front belt length (right side as worn)
前腰帶長 Front belt length
前三角闊 Front triangle width
前三角高 Front triangle height
綑邊丈巾闊 Foldover binding width
发表于 2012-2-15 20:56:12 | 只看该作者
1.LINING SWEEP里布下摆
2.LINING SLIT HEIGHT 里布开叉的高度
3.ZIPPER OPENING 拉链开口
4.BACK YOKE HEIGHT AT CENRER BACK后育克在后中处高
GMT+8, 2026-11-6 21:22 , Processed in 0.034608 second(s), 18 queries , Gzip On.
