查看: 390|回复: 1
初办
发表于 2012-2-14 14:39:45 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
1,collar & stand
collar, stand & neckline aer 1/4" sms. sandwich collar in stand. clean finish neckline w/ stand. sn. edge stitch collar & stand.
2, shoulder insert
5 thrd overlock join shoulder tab. w/front and back yoke and edge stich-do not stretch out.
3,sleeve
overlock sleeve opening,fold to inside 2 1/4' single needle top stitch. clean finish sleeve tab wich 3/8" seam & turn out ,single needle edge stitch both edges, single needle set tab on inside & make 1/4" single needle box. follow template for placement, set button at outside sleeve following template .button hole at tab end following template.
4,yoke
5 thrd overlock join and edge stitch seam do not stretch out at front or back!
5,pocket & flap
clean finish flap w/1/4" sm, clean and edge stitch . overlock top edge of pocket , turn down 1/2 " & sn top stitch . turn in pocket edges 1/2 & edge stitch set. make sure pocket & flap are centered .
6,darts
SN set bust dart sew 1/2 " past punch holes & press down, 5 thrd o/I set waist dart sewing 1/2 " past punch holes. press side sm toward center.
7,placket
clean finish center front packet & edge stitch.
8 , BK princess line
5 thrd overlock join seam, press towards center
9,buttons
set buttons at ft placket follow template. 7 onononfunctional button & a spare placed 1/2" below last button on placket. set buttons at sleeve tab, follow templatet.
请各位大侠帮忙,谢谢!!!!!!!!!
发表于 2012-2-14 14:39:54 | 只看该作者
1,collar & stand 上领和下领
collar, stand & neckline aer 1/4" sms. sandwich collar in stand. clean finish neckline w/ stand. sn. edge stitch collar & stand. 上领,下领和领线是1/4“SMS, 上领装入下领,反折领线和下领完成,上下领边间单针。
2, shoulder insert 搏头插入
5 thrd overlock join shoulder tab. w/front and back yoke and edge stich-do not stretch out. 搏肩章五线锁边,和前后担干间线。不要伸展。
3,sleeve 袖
overlock sleeve opening,fold to inside 2 1/4' single needle top stitch. clean finish sleeve tab wich 3/8" seam & turn out ,single needle edge stitch both edges, single needle set tab on inside & make 1/4" single needle box. follow template for placement, set button at outside sleeve following template .button hole at tab end following template. 袖口锁边,反折2 1/4“ 面间单针。反折袖带3/8”和反出, 单针间边线在两边。单针车袖带同时间1/4“屋仔。跟样办放置,在袖外钉钮跟办。钮门在袖带尾跟办
4,yoke 担干
五线锁边和边车,不要拉伸在后和前。
5,pocket & flap 袋和袋盖
clean finish flap w/1/4" sm, clean and edge stitch . overlock top edge of pocket , turn down 1/2 " & sn top stitch . turn in pocket edges 1/2 & edge stitch set. make sure pocket & flap are centered . 还口完成袋盖1/4”止口,反折间边线。锁顶边,反折下1/2“,面间单线。折入袋边1/2”间线。确保袋和盖在中间。
6,darts 死褶
SN set bust dart sew 1/2 " past punch holes & press down, 5 thrd o/I set waist dart sewing 1/2 " past punch holes. press side sm toward center. 胸褶间单针1/2“通过穿孔和烫倒下。五线车腰褶过1/2”过穿孔。烫侧骨向前中
7,placket 筒
clean finish center front packet & edge stitch. 还口完成前筒和间边线
8 , BK princess line 后公主线
5 thrd overlock join seam, press towards center 五线锁骨,烫倒向中间
9,buttons 钮
set buttons at ft placket follow template. 7 ononononfunctional button & a spare placed 1/2" below last button on placket. set buttons at sleeve tab, follow templatet. 装钮在前筒跟办。7粒没有作用的钮和一多余的钮在最后一粒下1/2“。 钉钮至袖带,跟办。
没图示,只能供参考。
GMT+8, 2026-11-7 00:49 , Processed in 0.025862 second(s), 18 queries , Gzip On.
