查看: 403|回复: 1
求教高手教我翻译一下!
发表于 2012-2-14 14:12:15 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
waist:India tape inside of waistband .1/4'' double stitch around waistband.CF entry.The 17 1/2'' onmetal zipper starts from TOP of waistline.With 1/4 double stitch to set the zipper.24L clean button inside for opening.Center front facing clean finished with lining.
front:Front wrap panel starts at at left side pocket edge.1st pleat from edge 2'',then 2nd pleat from 1st one 2'', 3rd pleat from 2nd one 2 1/4'' . At right side with one pleat at right side pocket edge. Front pocket from sideseam 2 5/8'' and below waistband 6 1/4''. Edge stitch at pocket opening .Front wrap with FACING inside edge stitch&BLIND STITCH at opening hem.
求帮忙啊!感激不尽
发表于 2012-2-14 14:12:23 | 只看该作者
朋友,这是条半截裙还是裤子吗?而且是包片的那种? 大概词面翻译下给你,可能有几个部位你跟纸样师傅探讨才能明白的。
waist:India tape inside of waistband . 腰位: 腰头内装带条(直译是印度带条)1/4'' double stitch around waistband. 腰头两边车1/4"双线。CF entry. The 17 1/2'' ononmetal zipper starts from TOP of waistline.With 1/4 double stitch to set the zipper. 前中腰线起装17 寸1/4"金属拉链, 车1/4" 双线装拉链. 24L clean button inside for opening.门筒开口内侧钉24号干净纽扣. Center front facing clean finished with lining. 前中里布包贴还口完成(干净子口)。
front:Front wrap panel starts at at left side pocket edge. 前片:前包裹片从左边口袋边开始 1st pleat from edge 2'', 第一个褶位在边位2寸的位置, then 2nd pleat from 1st one 2'' 第二个褶位在第一个褶位靠右2寸的位置, 3rd pleat from 2nd one 2 1/4'' 第三个褶位在第二个褶位靠右2寸1/4的位置. At right side with one pleat at right side pocket edge. 前片右侧只有一个褶位在右侧口袋边的位置。Front pocket from sideseam 2 5/8'' and below waistband 6 1/4''.前口袋位置离侧骨2寸5/8,腰头下6寸1/4. Edge stitch at pocket opening .袋口车边线。Front wrap with FACING inside edge stitch&BLIND STITCH at opening hem.前包裹片加里贴车边线&下脚边车挑脚线。
大意就是这样,你再对办衣研究下,很多专业名词还是不大懂,比如说印度带条,没听过,是一种什么样的带子?如果你知道,可以在这里跟我们解释解释。
GMT+8, 2026-11-7 00:49 , Processed in 0.027500 second(s), 18 queries , Gzip On.
