查看: 683|回复: 3
工艺单
发表于 2012-2-14 14:08:51 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
有谁能提供羽绒服的工艺单样本?急用!!!!
发表于 2012-2-14 14:08:54 | 只看该作者
1,collar & stand
collar, stand & neckline aer 1/4" sms. sandwich collar in stand. clean finish neckline w/ stand. sn. edge stitch collar & stand.
2, shoulder insert
5 thrd overlock join shoulder tab. w/front and back yoke and edge stich-do not stretch out.
3,sleeve
overlock sleeve opening,fold to inside 2 1/4' single needle top stitch. clean finish sleeve tab wich 3/8" seam & turn out ,single needle edge stitch both edges, single needle set tab on inside & make 1/4" single needle box. follow template for placement, set button at outside sleeve following template .button hole at tab end following template.
4,yoke
5 thrd overlock join and edge stitch seam do not stretch out at front or back!
5,pocket & flap
clean finish flap w/1/4" sm, clean and edge stitch . overlock top edge of pocket , turn down 1/2 " & sn top stitch . turn in pocket edges 1/2 & edge stitch set. make sure pocket & flap are centered .
6,darts
SN set bust dart sew 1/2 " past punch holes & press down, 5 thrd o/I set waist dart sewing 1/2 " past punch holes. press side sm toward center.
7,placket
clean finish center front packet & edge stitch.
8 , BK princess line
5 thrd overlock join seam, press towards center
9,buttons
set buttons at ft placket follow template. 7 ononfunctional button & a spare placed 1/2" below last button on placket. set buttons at sleeve tab, follow templatet.
请各位大侠帮忙,谢谢!!!!!!!!!
发表于 2012-2-14 14:08:56 | 只看该作者
看来你和我一样刚入门哦,刚开始看不懂尺寸表,现在看不懂工艺要求,总想放弃,可又不甘心,于是硬着头皮上,每天只有死记单词.
发表于 2012-2-14 14:08:58 | 只看该作者
1,collar & stand
这个款应该是上下级领,上下级领及领圈1/4"止口;下级领夹车上级领&领圈做环口,面间边线
2, shoulder insert
肩插幅:肩打带/前后担干做5线级骨.
3,sleeve
袖口做级骨,面间2 1/4' 单线.3/8阔止口袖搭带间边线;顶用单线定在袖内;袖带顶间1/4"方形线,定钮;钮及钮门位置请跟组客办;
4,yoke
担干,5线级合骨,面间边线
5,pocket & flap
clean finish flap w/1/4" sm, clean and edge stitch . overlock top edge of pocket , turn down 1/2 " & sn top stitch . turn in pocket edges 1/2 & edge stitch set. make sure pocket & flap are centered . 1/4"阔止口袋盖做环口,面间边线;袋口做级骨,走光边面间1/2"担线;袋沿边1/2"止口,边线上衫身.
6,darts
1/2" 胸褶止口倒向衫脚,面间边线;腰褶打5线;侧骨止口倒向前中
7,placket
前筒做环口,面间边线
后公主骨5线级合骨,止口倒向后中.
9,buttons
set buttons at ft placket follow template. 7 onononfunctional button & a spare placed 1/2" below last button on placket. set buttons at sleeve tab, follow templatet.
前筒右搭左,跟客办; 钉7粒钮,一粒士啤钮在最底钮下1/2";袖搭带钮位置跟客办
供参考!
GMT+8, 2026-11-7 02:09 , Processed in 0.028334 second(s), 18 queries , Gzip On.
