查看: 616|回复: 4
澳大利亚 - SAA 认证
发表于 2012-2-10 19:41:27 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
本人有个电子变压器,属于IEC 61347-2-2的, 我做完了IEC报告,然后拿去澳大利亚申请SAA。
需要提供澳洲差异,请问哪位大侠能给我一个61347的澳洲差异,万分感谢。
邮箱:禁留邮箱@163.com
发表于 2012-2-10 19:41:32 | 只看该作者
差异主要是在插头部分,其他的,没对比过。
 楼主| 发表于 2012-2-10 19:41:38 | 只看该作者
只有插头吗?因为像60065里面差异项还挺多的
发表于 2012-2-10 19:41:44 | 只看该作者
Deviations for IEC 61347-1 & IEC 61347-2-2 and AS/NZS 61347.1 & 61347.2.2
5 (5) General notes on tests
Rated supply
8 (10) Protection against accidental contact with live part
8.1.1 (-) Subclause 8.6 of AS/NZS 66065: 2003 apply
8.1.2 (-) Clearance and creepage distance is dimensioned in accordance with 8.1.3
8.1.3 (-) Clearance and creepage distance is dimensioned in accordance Figure 1
9 (8) Terminals, cable and cords
Screw terminals comply with section 14 of AS/NZS 60598.1
Screwless terminals comply with section 15 of AS/NZS 60598.1
Cables and cords comply with section 5 of AS/NZS 60598.1
17(15) Construction
17.1 (-) Socket-outlets in the output circuit do not accept plugs complying with IEC 60083 and IEC 60906
17.2 (-) Equipment with integral plugs for insertion into socket outlets comply with Appendix J of AS/NZS 3112: 2004
20 (18) Resistance to heat, fire and tracking
20 (18.2.1) Glow-wire test (750°C)
20 (18.2.2) Glow-wire test (650°C)
20 (18.2.3) Needle-flame test (30s)
 楼主| 发表于 2012-2-10 19:41:50 | 只看该作者
很好,非常感谢楼上的
GMT+8, 2026-11-11 01:57 , Processed in 0.069914 second(s), 18 queries , Gzip On.
