查看: 674|回复: 0
AS/NZS 3120中Current breaking test疑惑
发表于 2012-2-10 19:32:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
AS/NZS 3120中Current breaking test要求不甚明白:
(a) A plug shall be inserted in the socket with no current flowing.
(b) Immediately following each full insertion, a current as prescribed in Items (i) and
(ii) shall be passed through a circuit including the plug and socket for 15 s.
(c) The plug shall be then withdrawn from the socket under load at a rate of
approximately 150 mm/s, and shall remain withdrawn for approximately 105 s.
以上是说插头插入插座时要求不通电流,插入后立即通电维持15S, 之后插头拔出插座,拔离插座的状态维持105S; 然后继续开始第二个循环吗?那有这样的插拔设备可以做到这个吗?一般我知道是直接机械插拔或者带电插拔,这个要求好像有点复杂,我也不明白标准这么要求是基于什么考虑?
另外,以下这句话是不是表示,如果产品带接地,要求接地也通电流!Where an earthing contact and an earthing pin are included, the earthing terminal of the socket shall be connected to the neutral terminal during the test.
期待高手解答,谢谢先La!
GMT+8, 2026-11-11 03:46 , Processed in 0.026109 second(s), 18 queries , Gzip On.
