查看: 669|回复: 0
请教:AS/NZS 3112 插座测试用的安装盒尺寸
发表于 2012-2-10 19:31:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
3.14章,提及,Other socket-outlets shall be mounted in the minimum size intended enclosure or wall box.
Note: An appropriate metallic enclosure for socket-outlets on mounting plates of approximately H 114mm x W 72mm with 84mm certres is one of H 90 mm x W 60 mm x D 40mm(approximating dimensions of commonly available units).
怎么都看不懂这句话的语法,不清楚缩写 H,W,D到底是什么,不明白到底是个什么形状的东西,尺寸要求如何?
请哪位高手出手帮忙解答,万分感谢!
GMT+8, 2026-11-11 04:36 , Processed in 0.069306 second(s), 18 queries , Gzip On.
