查看: 711|回复: 1
新西兰官方关于澳洲认证
发表于 2012-2-9 23:44:20 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
How to comply
Step 1: Ensure products meet an appropriate standard
Lists of applicable standards are prescribed in the
[li] and
[/li][li]
[/li]Copies of applicable standards can be obtained from Standards New Zealand or Standards Australia. Suppliers should consult a testing laboratory for technical advice regarding applicable standards.
The supplier must determine which level of conformity from the applies to each product and conduct compliance actions accordingly. Advice regarding obligations imposed by the Notice should be sought from the supplier’s legal advisor.
These flow charts will help provide guidance for electrical and electronic product suppliers:
[li]
[/li][li]Electromagnetic compatibility flowchart
[/li]
Step 2: Prepare a product description
A product description of the marketed product identifies its use, brand name, and model number (at a minimum). A photo and technical description can also be supplied.
Step 3: Prove compliance through testing
The supplier accepts total responsibility for product conformity and needs to make a commercial decision on the level of testing required.
A test report or manufacturer’s specification may be sufficient evidence to support a declaration that the product meets a relevant standard recognised by RSM. For level of conformity 3 products, a test report from an accredited laboratory (which may be in NZ or overseas) is required. The test report must be in English. The supplier does not have to hold the original of the test report. A clear copy of the original is acceptable.
Step 4: Make a Supplier’s Declaration of Conformity (SDOC)
The is the document signed by a New Zealand supplier or a New Zealand agent of an overseas manufacturer or supplier to certify that a product meets applicable standards.
Step 5: Create a compliance folder
Compliance folders are a collection of documents assembled by the supplier to support the compliance declaration. A compliance folder contains:
[li]a product description
[/li][li]a signed Declaration of Conformity
[/li][li]a test report or other documented evidence of conformity (mandatory for levels 2, 3, A2, and A3 products).
[/li]
Step 6: Apply for a Supplier Code Number (SCN)
is a registration number obtained from RSM free of charge. It authorises the holder to use the C-tick compliance mark. A New Zealand Supplier Code Number consists of the letter “Z” and a unique numerical identifier.
Step 7: Label the product
A label indicates that the product complies with the applicable standards and establishes a traceable link between a product and the supplier responsible for placing it on the market.
Where a product is in a class to which level of conformity 1, 2 and 3 applies, the compliance label consists of:
[li]a compliance mark such as [sup]1[/sup] or RCM, and [/li][li]an unique supplier identification such as the Supplier Code Number [/li]
Where a product is a radio transmitter in a class to which level of conformity A1, A2 or A3 applies, the product must be labelled with a New Zealand supplier code number only.
The label must be legibly and durably applied on the external surface of the product. The compliance mark must be no smaller than 3mm in diameter and the supplier identification characters must be no less than 1mm in height.
pdf-l_..._nce-notice-2004.pdf (163.95 KB, 下载次数: 5)
发表于 2012-2-9 23:44:26 | 只看该作者
顶上,
GMT+8, 2026-11-11 19:52 , Processed in 0.056322 second(s), 21 queries , Gzip On.
