查看: 571|回复: 2
电视机能耗测试的图象模式选择问题?
发表于 2012-2-9 23:24:18 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
标准中有这样的规定:The contrast and brightness of the television set and the backlight level, if it exists, shall be set as originally adjusted by the manufacturer to the end user. In the case that a setting mode must be chosen on initial activation, the “standard mode” or equivalent shall be chosen. In the case that no “standard mode” or equivalent exists, the first mode listed in the on-screen menus shall be selected. The mode used during the test shall be described in the report.
“Standard mode” is defined as “recommended by the manufacturer for normal home use”.
我们实际的测试中是选择"standard mode"还是选择打开电视机时默认的图象模式?
非常感谢帮忙!
发表于 2012-2-9 23:24:24 | 只看该作者
其实就是工厂出厂前的默认设置。
发表于 2012-2-9 23:24:30 | 只看该作者
厂家推荐的模式 也就是默认模式
GMT+8, 2026-11-12 03:21 , Processed in 0.033869 second(s), 18 queries , Gzip On.
