查看: 561|回复: 2
求助UL 817 25.2 face 怎么理解进行测试?
发表于 2012-2-8 14:00:12 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
如题,那位大侠解下
发表于 2012-2-8 14:00:18 | 只看该作者
25.2.1 The face of a 2-wire parallel-blade attachment plug shall be in a plane perpendicular to the major
axis of the blades (compliance shall be determined by full insertion, as described in 26.6.1, into the cord
connector described in 26.1.1) and shall be 1.000 ±0.025 by 0.750 plus 0.000 minus 0.020 inch (25.40
±0.64 by 19.05 plus 0.00 minus 0.51 mm) with the blades centered, with a maximum 7/32 inch (5.6 mm)
radius at the corners. The 1-inch (25.4 mm) dimension shall be perpendicular to the width of the blades.
See Figure 25.2.?
下面不是可以看图吗?Figure 25.2.
发表于 2012-2-8 14:00:24 | 只看该作者
呵呵,发了段英文上来,没有解释
GMT+8, 2026-10-25 05:39 , Processed in 0.031158 second(s), 18 queries , Gzip On.
