查看: 655|回复: 3
UL817带保险丝测试标准
发表于 2012-2-8 13:35:02 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请问UL817 101.3最新标准是什么?因我只有UL817-2007版的。有没有中文版的。有的话共享下。
另外以下为UL 回复过来的,谁帮忙翻译下,谢谢
Twelve representative fuse assemblies were subjected to these tests.
A125 V ac, 60 Hzsupply source was connected in series with a calibrated circuit and a 20 A time-delay fuse. The calibrated circuit was adjusted to supply a test current of 200 A at a power factor of 0.70 to 0.80 without the assembly under test or the time-delay fuse in the circuit.
1. The blades of the device were inserted into a receptacle and cotton was placed around the body of the device, not in contact with the face. Each device was prepared by removing 0.5 inch (13mm) of the insulation from the end of each circuit conductor and twist to join the conductors. The circuit was energized and the test current was monitored until the fuse opened, causing the current to stop flowing. The test was repeated on two of the five remaining assemblies. The test was then repeated at a current of 1000 A on the three remaining assemblies.
2. The method above was repeated on 6 new samples except there was six (6) feet of cord beyond the protective-device enclosure.
 楼主| 发表于 2012-2-8 13:35:08 | 只看该作者
没人帮忙吗?
或是谁有UL817 101.3带保险丝插头的相关中文翻译版。。。给份~~谢谢
发表于 2012-2-8 13:35:14 | 只看该作者
ul 507产品所使用的插头
发表于 2012-2-8 13:35:20 | 只看该作者
国内只有一家测试通过了,这个挺不好做的!
GMT+8, 2026-10-17 03:14 , Processed in 0.051771 second(s), 18 queries , Gzip On.
