查看: 575|回复: 1
关于wiring harness之 FUII的片段解读
发表于 2012-2-8 13:30:18 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Form 1-N - This Recongnition Mark is used for harnesses consisting of four parts or less. Each piece of wire, fitting, splice, terminal block, wiring device, etc. is considered to be a part. Simple terminations of the eyelet, ring, open spade, or quick-connect types are not counted as a part when determing the form Recongnition Mark to be used.
请问上述FUII所述的,“Each piece of wire, fitting, splice, terminal block, wiring device” 和 “Simple terminations of the eyelet, ring, open spade, or quick-connect types ”所指部件分别都是神马?
发表于 2012-2-8 13:30:24 | 只看该作者
概述是指各种接头零件、快速端子,如圆盘端子、Y型端子、250端子...等
GMT+8, 2026-10-17 01:49 , Processed in 0.027018 second(s), 18 queries , Gzip On.
