查看: 2279|回复: 16
电线,插头需不需CE认证,怎样做?如果你客户要求CE认证要怎样说
发表于 2012-2-8 13:09:28 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
严格说插头不需要做,但很多公司不少客户要求做CE认证或有CE证书。
有些是不懂,有些则强烈要求。甚至去非欧盟国家也要求产品有CE认证。
电线,插头需不需CE认证,有权威的官方依据吗
如果要做怎样做?
如果你客户要求CE认证,你要怎样说服他不需要CE证书。
发表于 2012-2-8 13:09:34 | 只看该作者
不要做CE,但要做VDE
发表于 2012-2-8 13:09:40 | 只看该作者
插头跟电源线都不在CE的指令范围之内,所以,不需要做,如果乱用CE标志,当心受到CE的严惩!
发表于 2012-2-8 13:09:46 | 只看该作者
见2006/95/EC欧盟官方通报。
该通报的附录2,如下:
ANNEX II
Equipment and Phenomena outside the Scope of this Directive(不在该指令范围内的产品)
Electrical equipment for use in an explosive atmosphere
Electrical equipment for radiology and medical purposes
Electrical parts for goods and passenger lifts
Electricity meters
Plugs and socket outlets for domestic use(家用插头和插座)
Electric fence controllers
Radio-electrical interference
Specialised electrical equipment, for use on ships, aircraft or railways, which complies with the safety provisions drawn up
by international bodies in which the Member States participate.
家用插头插座不在LVD指令范围内,
因为欧盟范围内插头插座标准并没有统一,
CE最原始的意思就是欧盟通用。
但没有说电线不在该范围内,
因为目前欧盟有统一的电线标准,
而且与IEC是等效的,HD21和HD22,
所以,我个人觉得电线可以做CE,
但一般电线都是VDE认证,
这个认证标记表明除了符合欧盟电线标准外,
还符合VDE的内部决议,
似乎更为高级。
但有些插头插座产品是可以打CE标志的,
比方说带定时器的,带遥控的,
它们除了符合插头插座标准外,
还需符合另外的EN标准,如EN 60730,
这时候这个插头插座产品就属于另外一个产品范畴了,
插头插座标准变为次要标准,
有了统一的欧盟标准,就可以打CE标志了。
无其它附加功能的插头和插座,
是肯定不能打CE标志的。
附录3如下:
ANNEX III
Ce Conformity Marking And EC Declaration of Conformity
A. CE conformity marking
The CE conformity marking shall consist of the initials ‘CE’ taking the following form:
— If the CE marking is reduced or enlarged the proportions given in the above graduated drawing must be
respected.
— The various components of the CE marking must have substantially the same vertical dimension, which may
not be less than 5 mm.
B. EC declaration of conformity
The EC declaration of conformity must contain the following elements:
— name and address of the manufacturer or his authorised representative established within the Community,
— a description of the electrical equipment,
— reference to the harmonised standards,
— where appropriate, references to the specifications with which conformity is declared,
— identification of the signatory who has been empowered to enter into commitments on behalf of the
— the last two digits of the year in which the CE marking was affixed.
是关于CE标志的尺寸和形状要求。
发表于 2012-2-8 13:09:52 | 只看该作者
记者从检验检疫部门获悉,出口家用插头插座类产品因打上CE标志,遭欧盟通报、退货的案例在我省有的地区已经出现。
  据了解,CE标志是欧盟统一、通用的具有法律效力的安全标志。从1974年以来,欧盟实施的22个新方法指令几乎把日常的工业品都纳入了CE标志,只要通过了合格评定程序,就能够在产品上直接打上CE标志。但是,根据欧盟相关规定,其中2类非常常见的产品--家用插头、家用插座,却不在CE标志范围之列。
  由于历史原因,世界各国使用的插头插座的形状和尺寸种类繁多,相互能够一致、通用的范围非常小,给国际间人员交往造成极大障碍。欧盟虽然协调统一了绝大多数的规则、产品,但在插头插座的统一问题上只做了两项小的改变:一是家用插头把德国式和法国式的合二为一;二是统一了工业用的插头插座,并纳入了低电压指令,允许标注CE标志。除此之外还是维持现状,由成员国自己分别控制。现在,几乎是一个国家一个认证标志,较为知名的有VDE、BS、NF等。因此在插头插座上,可以看到同时出现许多国家的认证标志。
  欧盟在2008年出台了765/2008/EC和768/2008/EC两项旨在严格CE标志认证规定的法规,从2010年1月1日起,相关产品出口至欧盟,如果误用滥用CE标志,将受欧盟重罚。检验检疫部门提醒相关企业:一是及时把这一要求传达到营销、技术和质保等部门的相关人员;二是加强出厂检验,增加对家用插头及插座上认证标志的核对,不要出现误用CE标志的现象;三是要补充制度规定,把CE标志有无误用列入客户资料核查和厂检内容,保证按要求规范生产,避免出现返工甚至被通报或退货。
发表于 2012-2-8 13:09:58 | 只看该作者
目前欧盟的法规有点矛盾,
曾经和深圳技术贸易壁垒研究所的一位专家讨论起过,
某出口欧盟产品做过LVD,可以打CE,
做过EMC,也可以打CE,
将来可能符合ROHS,也可以打CE,
因此一个CE标志是代表符合一个指令,还是所有指令,
在欧盟方面还未明确规定。
但欧盟各官方一般对LVD指令关注较大,
因此,LVD指令不包括在内的产品尽量不要打CE标志。
也和VDE某工程师讨论过类似问题,
他们那边的内部规定是拖线板,就是一个插头拖几个插座的插板,
是可以打CE标志的。
发表于 2012-2-8 13:10:04 | 只看该作者
我们拖板是有打CE标志的,还有延长线有些客人要求一定要打CE标志!
发表于 2012-12-8 09:31:42 | 只看该作者
电线电缆,插头插座是可以做CE认证的。
而且我们做的都是欧盟公告号机构出证(Notified body )
发表于 2012-12-8 11:54:18 | 只看该作者
路过
发表于 2012-12-14 14:03:16 | 只看该作者
学习了!
GMT+8, 2026-10-17 11:15 , Processed in 0.094291 second(s), 19 queries , Gzip On.
