查看: 616|回复: 3
请教3512电线结构问题,感谢指教!!
发表于 2012-2-8 12:55:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请教3512电线结构问题,感谢指教!
按照活页意思:Maybe applied in two layers with an intermediate glass braid (optional).(也适用于双层与一个玻纤编织层)
请问:
1、3512按照活页字面意思是否应可以做成单层绝缘?
2、双绝缘结构是否有两种?即为双层绝缘和绝缘层+玻纤编织+绝缘层。
3、如做成双绝缘具体结构尺寸是多少?请详细举例说明。
感谢您的指点!!!!
发表于 2012-2-8 12:55:16 | 只看该作者
不管做双绝缘还是单层的,绝缘厚度都不可以小于他活页上区分开的平均厚度
发表于 2012-2-8 12:55:22 | 只看该作者
Firstly, make it fulfill the style page's description, there is specified description about the wire's construction, and combined with your own facing page's description, if applicable( cause, not each style of wire has its own facing page for a specified manufacturer).
发表于 2012-2-8 12:55:28 | 只看该作者
This style page can be found on both your FUS procedure and the UL website, but facing page, if available, only can be found in your own FUS procedure...
GMT+8, 2026-10-16 23:37 , Processed in 0.047866 second(s), 19 queries , Gzip On.
