查看: 601|回复: 1
二类电器是否可用X型连接
发表于 2012-2-8 11:48:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
220V的二类电器是否可用X型连接,如果行,支持标准?不行,相关标准?
发表于 2012-2-8 11:49:03 | 只看该作者
可以用X型连接,但是说明书上要有X型连接的注解. 例如灯具EN60598-1:2008/A11:2009
3.3.17 For luminaires with type X, Y or Z attachments, the mounting instructions shall contain
the substance of the following information:
– for type X attachments having a specially prepared cord:
If the external flexible cable or cord of this luminaire is damaged, it shall be replaced by a
special cord or cord exclusively available from the manufacturer or his service agent.
– for type Y attachments:
If the external flexible cable or cord of this luminaire is damaged, it shall be exclusively
replaced by the manufacturer or his service agent or a similar qualified person in order to
avoid a hazard.
– for type Z attachments:
The external flexible cable or cord of this luminaire cannot be replaced; if the cord is
damaged, the luminaire shall be destroyed.
GMT+8, 2026-11-30 17:42 , Processed in 0.066423 second(s), 19 queries , Gzip On.
