查看: 565|回复: 3
IEC60884 24.3章节求解
发表于 2012-2-8 09:55:21 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
24.3 The bases of surface type socket-outlets are first fixed to a cylinder of rigid steel sheet,
having a radius equal to 4,5 times the distance between fixing holes but, in any case, no less
then 200 mm. The axes of the holes are in a plane perpendicular to the axis of the cylinder
and parallel to the radius through the centre of the distance between the holes.
The fixing screws of the base are gradually tightened, the maximum torque applied being
0,5 Nm for screws having a thread diameter up to and including 3 mm and 1,2 Nm for screws
having a larger thread diameter.
The bases of socket-outlets are then fixed in a similar manner to a flat steel sheet.
During and after the tests, the bases of socket-outlets shall show no damage impairing their
further use.这是原文 讲解的是对于固定式插座底座的安装的要求大概是这个意思但是感觉好像从来没看到过这么做。
求大神讲解
发表于 2012-2-8 09:55:27 | 只看该作者
我们平时见到的都是暗装式固定插座。
发表于 2012-2-8 09:55:33 | 只看该作者
这个是关于固定式插座的底座安装测试,平时确实是很少见的。
 楼主| 发表于 2012-2-8 09:55:39 | 只看该作者
哦我知道了个是专门指的是一类产品吧一般性的产品这里都是 N/A吧
GMT+8, 2026-11-30 16:44 , Processed in 0.027735 second(s), 18 queries , Gzip On.
