查看: 516|回复: 4
UL目击测试的要求
发表于 2012-2-6 21:08:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
UL相关工程师进行目击测试,对工厂有什么要求?
发表于 2012-2-6 21:08:28 | 只看该作者
First, your factory should be covered by UL WTDP(witness test data program),
then, the related guys must know the standards' requirements and know how to do the tests,
Finally, all the test equipments related with UL must be calibrated correctly, and can be traced to CNAS, for this point, the UL witness engineer will focus on not only the calibration itself , but also the calibration reports for the equipments, so you also know how to deal with it....
发表于 2012-2-6 21:08:34 | 只看该作者
你想知道 哪个标准 的测试
 楼主| 发表于 2012-2-6 21:08:40 | 只看该作者
你想知道 哪个标准 的测试
UL817/62/758/764
发表于 2012-2-6 21:08:46 | 只看该作者
All above are standards related with wire and cable, but as per your description, I guess your factory must be a big one....
GMT+8, 2026-11-30 16:44 , Processed in 0.026940 second(s), 18 queries , Gzip On.
