查看: 535|回复: 3
UL 2149是什么结构
发表于 2012-2-6 20:56:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请问谁有ul 2149的page页,或者这种电子线的结构与其它什么规格的电子线类似啊
发表于 2012-2-6 20:56:59 | 只看该作者
Style 2419 Flat Cable.
Rating: 105 deg C, 300 Vac, Horizontal flame.
Conductor: 30 AWG - 20 AWG Bare, Flat copper. Area equal to AWG conductor size. Maximum 3 mil thickness. Conductor may be straight or irregular in shape.
Insulation: On each side of flat conductors 10 mil minimum PVC bonded together with 40 mil insulation width on outside edges of conductors and 24 mil minimum width insulation between adjacent conductors.
Assembly: Multi conductors. Length of insulated conductors not specified.
Standard: Appliance Wiring Material UL 758.
Marking: General.
Use: In internal wiring of appliances at temperatures not exceeding 105 deg C.
发表于 2012-2-6 20:57:05 | 只看该作者
You can login the UL website and download the style page for all AWMs...
发表于 2012-2-6 20:57:11 | 只看该作者
so what I know is this kind of AWM is not so common, it has flat insulation and conductors, not the round one.
so when you produce this kind of AWM, you must focus on the conductors' size, insulation thickness, the distance between the conductors and the distance between the edge and the conductors. and besides the requirements shown in the style page(general requirements), I think there will be a facing page(specified requirements) in your FUS procedure which describes more detailed about your products if your factory has already get the UL approval....
GMT+8, 2026-11-30 16:43 , Processed in 0.039088 second(s), 18 queries , Gzip On.
