查看: 491|回复: 2
满汉全席!UL电子线认证送样样品之解析!!!!
发表于 2012-2-5 23:38:18 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
最近接到一个关于UL电子线认证的送样要求明细表,小弟如水不深,不知其所云,请高人相助,帮忙解析一番。请看下面内容:
1. 200 feet PVC Insulated Single provided with 15 mil average insulation thickness, 13 mils minimum at any point, any solid or stranded conductor between 22 and 18 AWG, in any color rated 105C 600V.
2. 200 feet PVC jacketed single (similar to Style 1569), with 10 mils minimum wall thickness at any point, in any color rated 105C 600V.
3. 200 feet SRPVC Insulated Single provided with 9 mil average insulation thickness, 7 mils minimum at any point, any solid or stranded conductor between 22 and 18 AWG, in any color rated 80C 300V.
4. 15 feet FRPE jacketed round cable, contains 2 to 4 insulated single, with 5 mils average wall thickness, 3 mils minimum thickness at any point, in any color. This cable will be subjected to small scale flame testing.
5. 15 feet FRPE jacketed round cable, contains 2 to 4 insulated single, with 30 mils average wall thickness, 24 mils minimum thickness at any point, in any color. This cable will be subjected to small scale flame testing.
6. 200 feet FRPE jacketed round cable, contains 2 to 4 insulated single, with 16 mils average wall thickness, 12 mils minimum thickness at any point, in any color rated 80C 600V. This cable shall not contain any fillers or shielding.
7. If shielding will be employed during production, please also provide 50 feet of FRPE jacketed round cable similar to Sample 6 employing intended shielding.
8. 30 feet PVC Insulated Multiconductor Parallel Cable provided with 15 mil average insulation thickness, 13 mils minimum at any point, any solid or stranded conductor between 22 and 18 AWG, in any color rated 105C 600V.
以上八种样品,请解析 绝缘&外被 等结构方面要求(如绝缘的最小绝缘厚度或外被的最小绝缘厚度)。不甚感激!!!
发表于 2012-2-5 23:38:24 | 只看该作者
1.200英尺平均绝缘厚度是15mil聚氯乙烯无护套线,任何地方的最小厚度至少13mil,18-22号任何的单芯线或多股线,任何颜色,额定蚕食105℃,600v
发表于 2012-2-5 23:38:30 | 只看该作者
第一:你公司申请了这些认证,因此UL才需要这些样品;第二:为以免出错,你可以找UL负责工程师给详细中文清单。第三:准备好的样品应详细标识区分,并填写UL发给你的LIST。
GMT+8, 2026-11-30 15:08 , Processed in 0.025295 second(s), 18 queries , Gzip On.
