查看: 611|回复: 3
UL 3386 已经失效?我在UL标准库中找不到这个标准。
发表于 2012-2-5 23:29:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
各位,没看到失效公告啊。
另外,请问这些失效的标准哪里能找到公告啊?
发表于 2012-2-5 23:29:59 | 只看该作者
请上UL网站找吧。
发表于 2012-2-5 23:30:05 | 只看该作者
UL3386无卤电线是UL758里的一种型号。
UNDERWRITERS LABORATORIES, INC. APPLIANCE WIRING MATERIAL
Subj. 758 Section 3 Page 3386 Issued: Jan. 29, 1980
Revised: Nov. 15, 2000
Style 3386 Irradiated Polyethylene Insulated Wire.
_______________________________________________________________________
Rating 105°C, 600 Volts.
*Conductor 32-4/0 AWG solid or stranded.
Insulation Irradiated polyethylene. See Facing Page For Compound
Designation.
Minimum Average Minimum Thickness
Conductor Size Thickness, Mils at any point, Mils
32-9 30 27
8-7 45 40
6-2 60 54
1-4/0 80 72
*Shield (Optional)
Jacket (Optional except when shield is used) - PVC, 30 mil min.
average, 27 mil min. at any point.
*Standard Appliance Wiring Material UL 758.
Instructions Detailed Examination.
*to UL Physical Properties, same as Class 43.
*Representative Spark Test.
UL (4) Detailed Examination.
*Counter-Check (4) Physical Properties, same as Class 43.
*Program (4) Heat Shock.
* (4) Deformation.
* (4) Cold Bend.
* (4) Horizontal Flame Test.
*Marking General.
Use Internal Wiring of Appliances., Tags may indicate the
following: 2500 Volts Peak - For Electronic Use Only.
RLS_AWM\\2466
 楼主| 发表于 2012-2-5 23:30:11 | 只看该作者
多谢版主,能提供个链接吗,哪里能找到这些信息。我在UL上怎么也搜不到。
GMT+8, 2026-6-14 22:41 , Processed in 0.047373 second(s), 18 queries , Gzip On.
