查看: 488|回复: 1
求UL62认证目击测试文件,谢谢!
发表于 2012-2-5 21:26:48 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
小弟求UL62认证目击测试文件,
感谢
发表于 2012-2-5 21:26:53 | 只看该作者
You can reference UL 62 and its FUII, especially in the FUII, you can see which tests need the UL engineer witness, but some suggestions, I can show you:
1. Be familiar with UL62 and UL1581, know how many tests need to be done, and the corresponding test methods;
2. Make sure that all the equipments are calibrated and can be traced to CNAS level;
3. Prepare enough samples and related traceability documets(COC) for convenience...
GMT+8, 2026-11-30 14:36 , Processed in 0.025794 second(s), 18 queries , Gzip On.
