查看: 494|回复: 4
UL AWM FUS样品测试地点的转移利弊分析
发表于 2012-2-5 21:25:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
之前,我司的UL跟踪检查电线在美国托马斯测试,现想转移到苏州美华,经沟通美华同意。
好处:1.运费减少;2.都是中国人,好沟通;
但不知如此是否有不好之处?有人说如何是IMP的样品,那你们就死惨了。但我不知何为IMP样品,问他也没下文。
所以在此请教大家
发表于 2012-2-5 21:25:16 | 只看该作者
不清楚耶,待指教,不过我们公司目前为止电线跟踪服务都是寄到香港测试的
 楼主| 发表于 2012-2-5 21:25:22 | 只看该作者
我司当时在美国托马期申请的,
发表于 2012-2-5 21:25:28 | 只看该作者
IMP is increased monitor procedure, when so many VNs are issued and the sample tests can not fulfill the UL's requirements, then IMP will be effective...that means IMP is a punish policy conducted by UL, normally, you don't need to be afraid of this procedure, just consider the basic condition, that's ok..
So make a conclusion, I suggest to send the regular FUS samples to UL suzhou office, it's more convenient...
 楼主| 发表于 2012-2-5 21:25:34 | 只看该作者
thank you very much
GMT+8, 2026-11-30 14:53 , Processed in 0.037679 second(s), 18 queries , Gzip On.
