查看: 537|回复: 2
UL AWM Marking之间距离
发表于 2012-2-5 21:23:27 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
UL AWM 1007 EXXXXXX 20AWG(0.519mm2) 80℃ 300V UL AWM I A 80℃ 300V FT2 XXXXX
我曾在一个文件上看到的,如此规定:UL与AWM之间的距离为15,但不是UL标准文件,所以一直怀疑,现在此请教大师!
发表于 2012-2-5 21:23:33 | 只看该作者
UL FUII and it's full name is UL Follow Up Inspection Instruction. If you have the hard copy of the FUS procedure, then normally, it should include that FUII, it's very useful....
 楼主| 发表于 2012-2-5 21:23:39 | 只看该作者
我有FUS procedure.但里面没有规定UL与AWM之间的距离
GMT+8, 2026-11-30 14:36 , Processed in 0.152859 second(s), 18 queries , Gzip On.
