查看: 528|回复: 1
为何电线火花机误报警
发表于 2012-2-5 21:18:25 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
为何电线火花机常报警,而一检查却并未出现击穿?请高人赐教
发表于 2012-2-5 21:18:31 | 只看该作者
1.How do you verify the wire which has the alarm information?
2.If step 1 shows your verification method is ok, and the wire is really no flash over, then you can use a broken wire and let it go through the spark tester, check whether the alarm happens...
GMT+8, 2026-11-30 14:36 , Processed in 0.035085 second(s), 18 queries , Gzip On.
