查看: 697|回复: 2
求助 UL 62 电线老化试验取样要求
发表于 2012-2-4 15:18:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
有哪位知道,符合UL62 标准的电线进行老化试验时取样数量是多少?似乎UL1581中未提及,在哪个标准内有详细说明吗?
发表于 2012-2-4 15:18:52 | 只看该作者
UL 2556
4.2.4 Preparation of specimens
4.2.4.1 Sample selection and number of specimens
Samples shall be taken from a wire, cable or cord, finished or during manufacture, at any time following
curing of the compound, where applicable.
A minimum of six specimens per sample shall be tested ²as received² and after accelerated aging or liquid
immersion. If the specimen breaks outside of the gauge marks or the grips of the mechanical
extensometer at a value below that specified as the acceptable minimum, the test results shall be
disregarded and the test shall be repeated with another specimen.
要求最少取6个样板.
发表于 2012-2-4 15:18:58 | 只看该作者
正在找这资料,谢谢!
GMT+8, 2026-10-25 04:44 , Processed in 0.193674 second(s), 19 queries , Gzip On.
