查看: 563|回复: 2
请叫高手指点UL244几点,或者内行帮忙翻译几句话,谢谢,再谢谢
发表于 2012-2-4 13:54:56 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
关于绝缘耐压测试的
An essentially is to be applied as noted in (a)--(c).
(a) between each different type of primary circuit (for example,the input and output circuits of a control both of which are intended to be conductively connected to the branch circuit in the end application).
(b) Between terminals of opposite polarity on a capacitor that is connected across the line
(c) Across any other insulation or spacing involving a primary circuit that is required to reduce the risk of fire,electric shock,or injury to persons(for example,at the input and output terminals of an isolation device)
谁帮我分析下,这电压到底要加在哪个地方,第一点是什么电路?第二点是什么电容?第三点我连方向都摸不到
急啊,很急, 谢谢各位先,是UL244A里面的,我们的产品是遥控插座,郁闷。
 楼主| 发表于 2012-2-4 13:55:02 | 只看该作者
急啊
桐子们 帮帮我啊
发表于 2012-2-4 13:55:08 | 只看该作者
a) For example, primary current (input L) and isolated secondary circuit;
b) For example, line-voltage current carrying parts(input L) and grounding G;
c) For example,at the input and output terminals of an isolation device;
GMT+8, 2026-10-25 01:40 , Processed in 0.050615 second(s), 18 queries , Gzip On.
