查看: 456|回复: 2
大家来看看英式插头申请认证的这一要求
发表于 2012-2-4 13:43:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
BS 1363-1铭牌这一章节规定如果不是用在整机的插头,必须贴含有如下内容的标签,我想请教大家这个标签怎么个形式比较好,即就写如下几段话吗?
还有此标签贴在如何位置?每个出货的插头都要贴这样的标签吗?
7.3 Except where a plug fitted with a flexible cord is supplied direct to a manufacturer for incorporation in
other equipment, the free end of such an assembly shall have a label attached which shall include the
following:
a) the statement: “The flexible cord of this plug must be connected to a piece of equipment before being
plugged into a socket-outlet.”;
b) the maximum rating, in amperes, of the equipment to which it may be fitted (as given in Table 2);
c) the colour code of the cores of the flexible cord as follows:
“IMPORTANT. Wires in the mains lead are coloured in accordance with the following code:
Green/yellow Earth (if any)
Blue Neutral
Brown Live”;
d) if the plug is fitted with a 2-core flexible cord, the following statement:
“This lead must not be used with equipment requiring the protection of an earth continuity conductor.”
发表于 2012-2-4 13:43:23 | 只看该作者
标签贴在尾部
每条都要贴
因为卖到市场,必须教人如何使用
发表于 2012-2-4 13:43:29 | 只看该作者
适用于可拆线的BS头
GMT+8, 2026-8-7 06:53 , Processed in 0.225943 second(s), 18 queries , Gzip On.
