查看: 469|回复: 2
求IEC类插头摇摆测试标准
发表于 2012-2-4 13:39:42 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
高手指点下IEC类插头摇摆测试标准,电压电流参照标准。
发表于 2012-2-4 13:39:48 | 只看该作者
IEC 60884 标准在论坛搜索一下
发表于 2012-2-4 13:39:54 | 只看该作者
The flexible cable is loaded with a mass such that the force applied is
– 20 N for accessories with flexible cables having a nominal cross-sectional area exceeding
0,75 mm2;
– 10 N for other accessories.
A current equal to the rated current of the accessory or the following current, whichever is the
lower, is passed through the conductors:
– 16 A for accessories with flexible cables having a nominal cross-sectional area larger than
0,75 mm2;
– 10 A for accessories with flexible cables having a nominal cross-sectional area of
0,75 mm2;
– 2,5 A for accessories with flexible cables having a nominal cross-sectional area less than
0,75 mm2.
The voltage between the conductors is equal to the rated voltage of the specimen.
The oscillating member is moved through an angle of 90° (45° on either side of the vertical),
the number of flexings being 10 000 and the rate of flexing 60/min.
NOTE 4 A flexing is one movement, either backwards or forwards.
60884-1 ? IEC:2002+A1:2006
GMT+8, 2026-5-1 07:30 , Processed in 0.040838 second(s), 18 queries , Gzip On.
