查看: 507|回复: 1
VDE对移动式插座的规定
发表于 2012-2-4 13:34:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Portable Socket-outlets
Testing Requirements for the Temperature Rise Test according to DIN VDE 0620-1
With immediate effect, cords having a cross sectional area of 1,0 mm² are not allowed for portable socket-outlets with VDE or VDE GS Mark. Tests performed by the VDE Institute have shown, that portable socket-outlets having cords of this cross sectional area always exceed the allowed temperature limits according to DIN VDE 0298-300. The VDE Institute has informed his customers about this fact by the following letter: 16:50 23.02.2009
For portable socket-outlets – consisting of socket-outlet, cord and plug – the temperature rise test according to DIN VDE 0620-1:04-2005, differing from table 20, has to be applied at a testing current of 20A on all parts of the product (socket-outlet, cord and plug) – irrespective of the cross sectional area, see also EK1 decision No. 393-08.
Therefore it is necessary, to supplement the testing requirements according to the safety-relevant gaps found in the standard.
This means, that e. g. a temperature rise test on portable socket-outlets according to DIN VDE 0620-1:04-2005 at a testing current of 20A is necessary irrespective of the cross sectional area. If for this product, a cord having a cross sectional area of 1,0 mm² is used, a temperature rise measurement directly on the cord is also involved.
Based on the tests performed so far on 1,0 mm² cords the allowed temperature limits according to DIN VDE 0298-300 (VDE 0298 Part 300):2004 tables 4A or 4B are always exceeded. For this reason it is no longer possible to certify products having a cross sectional area of 1,0 mm².
The current marks approvals will be adjusted, i. e. the cross sectional area of 1,0 mm² will be deleted from the certificates.
Hence from now on with immediate effect, cords having a cross sectional area of 1,0 mm² are not allowed for portable socket-outlets with VDE or VDE GS Mark. This fact will be published on our homepage in the internet.
A respective update of the appendices to the relevant marks approval certificates will be sent to you shortly.
 楼主| 发表于 2012-2-4 13:34:41 | 只看该作者
学习了,期待中。
你能不能少灌点水?到处留下没有营养的回复
GMT+8, 2026-11-30 13:57 , Processed in 0.025554 second(s), 18 queries , Gzip On.
