查看: 521|回复: 2
BS1363-1不可拆插头的保险丝取出方式
发表于 2012-2-4 13:01:05 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
BS1363-1不可拆插头,在保险丝盖拿出时,也要求保险丝一同出来吗?请高人指教
发表于 2012-2-4 13:01:11 | 只看该作者
3.11
fuse carrier
a movable or removable part designed to carry, retain, cover and/or remove the fuse link
12.5 In non-rewirable plugs, where the fuse link is retained by means of a fuse carrier, this device shall be either:
a) non-detachable during normal replacement of the fuse link; or
b) readily identifiable in relation to its plug by means of marking
应该是的吧。定义里面有个RETAIN。
 楼主| 发表于 2012-2-4 13:01:17 | 只看该作者
thank you
You are a professional
GMT+8, 2026-11-30 14:02 , Processed in 0.025635 second(s), 18 queries , Gzip On.
