查看: 496|回复: 1
请教BS 1363中 12.6.1(C)测试方法
发表于 2012-2-4 12:43:04 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Non moulded on, non-rewirable plugs are tested with the flexible cord supplied. The plug
pins are clamped in the vertical position using a jig with the plug pins uppermost. The
plug lead fitted shall be suitable fitted with a cord totalling 1m in length and a 3 kg weight
applied to the end.
With the weight initially held 0.5m from the end of the cord anchorage, and at the same
height, the weight is allowed to fall freely. This test is carried out 5 times.
After the test the plug cover shall be in place and show no damage.
我对12.6.1(C)描述理解的不透,不知此试验如何做才是正确的,请高手赐教!谢
发表于 2012-2-4 12:43:09 | 只看该作者
能不能具体点?那部不明白
GMT+8, 2026-8-7 05:34 , Processed in 0.034433 second(s), 19 queries , Gzip On.
