查看: 667|回复: 6
谁懂SPD,赐教!(关于EN 61643-11-2007浪涌保护器)
发表于 2012-2-3 16:30:25 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
两个问题:
1。SPD(浪涌保护器)的国家标准是多少,我只知道EN 61643-11
EN 61643-11:2007版比2002版有哪些变化
2。SPD type 1,type 2 and type 3怎么区别?
发表于 2012-2-3 16:30:30 | 只看该作者
GB 18802.1—2002 低压配电系统的电涌保护器(SPD) 第1部分:性能要求和试验方法
(相当于IEC61643—1:1998)
GB/T 18802.21—2004 低压电涌保护器 第21部分:电信和信号网络的电涌保护器(SPD)—性能要求和试验方法
 楼主| 发表于 2012-2-3 16:30:36 | 只看该作者
高手,你有GB 18802.10的标准吗
发表于 2012-2-3 16:30:42 | 只看该作者
应该就是60335里讲的一类,二类,三类器具的差别一样
发表于 2012-2-3 16:30:48 | 只看该作者
保护水平不一样, 1级最高, 3级最低,
这跟用途有关.
 楼主| 发表于 2012-2-3 16:30:54 | 只看该作者
公司有一款SPD,需要认证。。。。
但标准不全,测试方法哪位高人通晓,诚心赐教。
发表于 2012-2-3 16:31:00 | 只看该作者
关于EN61643-11-2007的变更
KEMA网站的一个信息也许可以参考:
Starting July 2009, the EN 61643-11: 2002 standard for surge protective devices will no longer be valid. It will be replaced by a new version, EN 61643-11:2002 + A11:2007. This amendment is based on the new version of the IEC 61643-1:2005 (2nd. Ed). Several testing parameters have been changed in the new version.
New testing parameters
The new versions of EN 61643-11:2002 + A11:2007 and IEC 61643-1:2005 (2nd. Ed.) The standards for Class I, II and III Surge Protective Devices (SPDs) are now more in line with each other. The most important changes in the new EN 61643-11:2002 + A11:2007 standard are several new testing parameters. The thermal stability test is now carried out in smaller increments. The values for the short circuit test have been changed and the test set-up for the Temporary Over Voltage characteristic test has changed.
How this affects manufacturers
After July 2009, the existing certificate based on EN 61643-11:2002 will no longer be valid and you will need to obtain new EN 61643-11:2002 + A11:2007 certification.
GMT+8, 2026-11-30 15:48 , Processed in 0.028271 second(s), 19 queries , Gzip On.
