查看: 422|回复: 2
请问VDE导体要求?
发表于 2012-2-3 16:20:24 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请问VDE导体要求,一般软导体参照是GB3956、IEC60228、VDE0295我只看明白了单支导体的最大直径,但是没有看明白是否可以用单支导体来生产。请高手指教?
发表于 2012-2-3 16:20:30 | 只看该作者
IEC 60228内有说明,导体会分为4类, class 1, 2, 5, 6.要看电线种类及用途.
The conductors have been divided into four classes, 1, 2, 5 and 6. Those in classes 1 and 2
are intended for use in cables for fixed installations. Classes 5 and 6 are intended for use in
flexible cables and cords but may also be used for fixed installations.
? Class 1: solid conductors.
? Class 2: stranded conductors.
? Class 5: flexible conductors.
? Class 6: flexible conductors which are more flexible than class 5.
发表于 2012-2-3 16:20:36 | 只看该作者
IEC60228是导体标准,
具体采用什么导体,电线标准里面有规定.
GMT+8, 2026-11-30 16:10 , Processed in 0.025904 second(s), 18 queries , Gzip On.
