查看: 451|回复: 0
哑铃厚度测量
发表于 2012-2-2 12:49:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
UL1581中有规定的:在标志线处,标志线内6MM及19MM处共测试4点取最小值--440.24 The thickness of the specimen is to be taken as the smallest of four measurements to 0.001 inchor 0.01 mm, two of which are to be made at 1/2-inch or 13-mm intervals between the bench marks on oneedge beginning 1/4 inch or 6 mm from either mark, with the other two measurements being made atcorresponding points on the opposite edge.
GMT+8, 2026-11-30 16:10 , Processed in 0.072039 second(s), 18 queries , Gzip On.
